P500 Help With Diagnosis
Fatsquatch
Fatsquatch
Approved Member
120,623
1,006,909
Hidden
Roughed up a template.
I'd say it's bent.
What say y'all?
P500:
P520, aligned with main body of arm:
P520, aligned with ball joint angled end of arm:
I don’t know if it matters but that is the front half of the arm in the mounted pics and back half of arm in the removed pics. Assuming the front and rear halves of the arm mount level then yes it’s bent. But for the sake of being sure I’d check the same sides of the arms with your template. 👍🏻
P
pappyo
613
2,453
This Election is OVER.
SMITTY brain hurts.
Order up the the parts <> Time to Quit Thinking & Talking!!
My vote is in for ARCHED & NEW BALL JOINTS
Get "Er-Done" so you can do it Again.
futzin
futzin
4,741
34,760
Kentucky
I was starting to think I wouldn't find a smoking gun. But the camber was so far out after replacing the outer tie rod and adjusting toe . . . wasn't happy.
Quite possibly other smaller issue(s) I'm not seeing that may be adverse; but hopefully this is the vast majority of the problem.
211,163
Congrats on the find.
futzin
futzin
4,741
34,760
Kentucky
Update:
Got some virtually unused arms from a forum member, installed on machine. Re-set tie rods adjustments to factory. No change, still bad toe out on passenger side.
Started looking harder at the mounting tabs and alignment of them. Put a straight edge on both sides (upper arm mounts. Passenger side upper a-arm mounts are not in alignment as the driver's side is. BTW, this is where @lee said to take a closer look.
Driver's side pic:
20231008 145506
Passenger side:
20231008 145706
20231008 145732
I could use some advice.
Fatsquatch
Fatsquatch
Approved Member
120,623
1,006,909
Hidden
Did you have any trouble bolting the new-ish arms into the tabs?
The Green Goat
The Green Goat
2,363
17,455
Start looking for cracked paint on the frame.
211,163
Update:
Driver's side pic:
Passenger side:
?????? Is it time to make sure 100% your steering box is good?
Reactions: Fatsquatch
futzin
futzin
4,741
34,760
Kentucky
Haven't found any yet, on the frame. The issue arose from a pinch situation, as opposed to a hard hit. I feel like a bent frame is unlikely, but I don't much know what I'm doing really.
There is some slight paint cracked at the passenger rear upper arm mount (the one with the obvious bent tab, which I've 'straightened' with a hammer).
