Major General 2024 Talon 1000R-4 Build Thread
Coeus
Coeus
Major General
75,435
687,881
Signal Mountain, TN
  2. Talon R4 LV
What is the pro kit you speak of?
The AUX switch harness i sent you?
If so. Middle should be off. No backlighting.
If up and down are reversed then it may just be the rocker cover was installed upside down.
Doh… damn autocorrect… the pinoeer kit you sent that had the horn/harzard option
Coeus
Coeus
Major General
75,435
687,881
Signal Mountain, TN
  2. Talon R4 LV
The Aux switch you sent was perfect!
Coeus
Coeus
Major General
75,435
687,881
Signal Mountain, TN
  2. Talon R4 LV
Oh.. turnpro kit.
Mwas there not yellow wires coming off them? What did you hook them too?
Hooked up left to left but turns on when you click switch to the right
IMG 6347
Coeus
Coeus
Major General
75,435
687,881
Signal Mountain, TN
  2. Talon R4 LV
Wiring almost 100% wrapped up… everything is ran and either zip tied in or staged for tightening… waiting on a couple plates from Crossroads 3D, whip mounts, and need to pick up screws for mounting Auxbeam
IMG 6359
IMG 6360
Ground bus bar
IMG 6361
IMG 6362
Turn pro extra wiring.. not sure what to do with them…
IMG 6363
Aux/key-on bus bar controlled by DPDT
IMG 6364
Testing that runs to back function. Whips and stereo
IMG 6369
IMG 6370
IMG 6371
IMG 6372
JenElio
JenElio
81,836
712,675
Loxahatchee, florida
View attachment 429535View attachment 429536
Ground bus bar
View attachment 429537View attachment 429538
View attachment 429541View attachment 429542View attachment 429543View attachment 429544
Looking good General 👍 Did you run some extra wires front to back for future shît?
