Major General 2024 Talon 1000R-4 Build Thread
Coeus
Coeus
Major General
75,451
687,932
Signal Mountain, TN
  2. Talon R4 LV
Drilled out a hole through SuperATV stiffener to attach the front skid plate
IMG 6240
IMG 6242
Phantomhunter1
Phantomhunter1
104
578
Might have a problem with rubbing here between the frame stiffener and the a-arm guards… anyone run into this issue?
View attachment 428331View attachment 428332
Grab the Jack and you’ll find out pretty quickly. Dremel can shave down the A arm guard easily enough though.
I had that problem on my P1k as well. The frame stiffened was very close. I did exactly as mentioned. Just used a cut off wheel and cut a arm guard back so I had about 1/2" clearance.
Coeus
Coeus
Major General
75,451
687,932
Signal Mountain, TN
  2. Talon R4 LV
I had that problem on my P1k as well. The frame stiffened was very close. I did exactly as mentioned. Just used a cut off wheel and cut an arm guard back so I had about 1/2" clearance.
Awesome! That sounds about right… might have to cut some off that back wing area as well
