Rayger143
Rayger143
3,304
28,834
Winfield, BC Canada
Mine is on the cover but I dont have a light
0506848C A4CC 4B2F B3E5 10CF40DB89A6
SH21
SH21
126
661
NH
Not today, but Sunday. Took her for the maiden voyage on the ice. Helped a couple buddies move their bobhouses and did a little fishing. Saw some on the fish finder but they were tight lipped. Overall about 15 miles on the lake. Only took one picture, touch screen and fingers and -15 windchills don’t mix well.
82E378DE 8074 4ACC 88C8 52810724EDAC
Stateboy
Stateboy
299
1,740
Wolverine, MI
Wrestled with a license plate mount and picked up a recovery shackle. Tried mounting the plate/light on the roll bar but it interfered with the dump bed. Hopefully LEO won’t hassle me because it’s angled.
View attachment 317132View attachment 317133
You shouldn't have a problem with law enforcement. I've seen boat and utility trailers with plates mounted sideways on their fender (some without the required light). I only stopped them if it was a slow day and then looked for "other" things to consider. Otherwise, it was just a warning (I didn't write tickets for nonsense like that).
StewB
StewB
768
3,557
Utah requires a light for it to be street legal.
I found this LED light on amazone for $12 or so and it's worked so far. I tapped into the tail light for power so if the lights are on, the plate is lit.
1643857180268
A
AZBoatHauler
55
288
AZ
Reactions: JenElio and toddvdh
Hillbillytnt
Hillbillytnt
559
2,053
Ky
I installed the high beam light bar trigger from the club store to control a small light bar in the front. I ran it through a seven pin on/off/on switch so I can have it on with lights or just on or off. I repurposed the seven pin after replacing it with the ten pin key on /aux power switch from the store. Everything I get from the club store is top shelf.
Wellzy
Wellzy
269
900
SW Wisconsin
Same here, looks great there and is always showing even with the tailgate down. My plate is from Azon and is metal. When I mounted it, I put several stacked small washers behind the plate so there is a slight gap for air between plate and plastic shield. Never has it gotten hot, great place for a plate!
IMG 9002
N
Nvrgiveup
Finished cleaning up my dual battery and switch plate setup. I know a lot of ppl dislike using rivets but for me, they will be MUCH easier to mess with than trying to hold onto a nut to remove a bolt/screw. Couldn’t have done this without the help of all the people on this forum!
I also gotta say that I really like the fact that I can have accessory juice with key on or key off via the DPDT on-off-on switch.
C9CE525C 8DC2 4037 BA3B D51F8F3B0469 6C21C989 F9E7 4D08 859B 358A507A598C
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,226
Oshkosh, Wi
Turns out my spare Superwinch was more than full of mud. It previously stopped going to free spool and it was full of mud. It also had a broken magnet mount and the motor was locked up with corrosion and mud. Motors are indefinite back order.
Enter the replacement winch. Traveller 6000. Very similar line speed and power consumption to the Superwinch and 6000lbs pull capacity with a wireless remote. Even the wife said " it looks cooler on there"
We will see how this 3 year warranty works. I'm certain this will get used. I'm a bit worried about only 45ft of cable but give it a year and I'll have 55' of Amsteel rope on there. Otherwise there's 55' of Amsteel in my spares bag when the stock stuff comes apart. Winch definitely looks like a beast and sounds better/smoother than I expected
PXL 20220207 002801996
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,240
hondasxs.com
Good deal! Hope it serves you well.
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,240
hondasxs.com
View attachment 318100 View attachment 318101
Very cool
Reactions: Lady01 and JenElio
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,226
Oshkosh, Wi
3 year warranty was a selling point and locally available at tractor supply. It sounds a lot better than I expected. If Pioneer Takeover goes like last year maybe I can run it at near full load for 150-200ft on trail 26. My poor driver's door hinges probably don't want to get relocated again
A
AZBoatHauler
55
288
AZ
  • Haha
Reactions: JenElio
