2018 P1000-5 Rattle in motor
Hello_Darkness
Hello_Darkness
664
2,671
Just to the right of nowhere
No I’m saying I’m going to do both. Isolate the motor off trans and also pull the pan. Truly hoping it is possibly just the clutches. I appreciate all the help gentleman. Hoping I can get this figured out soon and hit the first honey hole.
Taking the clutches off means removing the whole rear of the engine, then I don't believe the engine would start due to transmissiom oil pressure issue possibly.
Reactions: ChadD and Rayger143
Duramax1021
16
41
Key largo
IMG 0215
Just realized something. Isn’t there supposed to be a guide between the chain tensioner and timing belt? I’m not really seeing the chain get any tension from the tensioner at all.
Reactions: ChadD
Hello_Darkness
Hello_Darkness
664
2,671
Yes, there should be a "guide" on both sides of the timing chain. One is usually a yellowish plastic and the other has rubber edges molded to a metal center.
I think you found your noise.
I would definitely replace the chain and tensioner foot for sure.
906UP
906UP
15,013
142,611
da Yoop
Not sure if you're following what @Hello_Darkness is saying, there is no "removing the transmission".....it's inside the engine. The subtrans is just a transfer case, nothing is spinning if the buggy is stationary.
906UP
906UP
15,013
142,611
da Yoop
Question is "where did it go?". Better pull the oil pan also and clean out the debris
Hello_Darkness
Hello_Darkness
664
2,671
Duramax1021
16
41
Key largo
Which takes me to my next question now.. seems like these tensioners actually do go bad often. Should I keep it as a spare or return it. The one I took off seemed perfectly fine.
Reactions: ChadD and JenElio
DRZRon1
DRZRon1
1,433
4,387
Haven’t heard any reports on here of the tensioners going south - the Honda master man will give ya some good feedback as well. Hondabob has >40k miles -
On his motor - no tensioner issues
Hello_Darkness
Hello_Darkness
664
2,671
I doubt you'll be able to return it, we don't take open box stuff back, especially special order things like that.
I've never replaced one on a 1000 series engine in the almost 10 years they've been around
