P1000 Issue with bed rubbing rear panel
K
KritzSXS
10
Canada
The plastic edge of the bed on my 2023 1000-3 rubs my rear panel right at the bottom of the window when I raise or lower the bed and I don’t really see any way to correct this. Has anyone else had this issue?
IMG 7255 IMG 7890 IMG 7889
116,520
Welcome from the States.
First post, youve been a member for a year so you should know that you need to post pics of your rig to start with please POIDH
Also, we need a bit more Info on what your talking about to serve you better. Hard or soft rear panel?
And again, post some pics of the problem your having. Kinda just throwing darts at it otherwise. Thanks.
Reactions: TxDoc
K
KritzSXS
10
Canada
Sorry my bad! Post has been updated. Thank you.
116,520
No worries thanks for the pics.
these guys get mean as snake if you hadn't😉
Base P1K3 and a Hard panel. Not sure on the 3’s? I would double check my part numbers and make sure you dont have a P1K5 Panel, might make a difference unless it fits both?
If it is the correct one, Ive read in some posts that it can be a bear to adjust correctly for fitment. Might want to search something like “mid Hard panel Installation” up top and see what others have done.
Reactions: TxDoc and CID
Hello_Darkness
Hello_Darkness
623
2,555
Just to the right of nowhere
They just suck and it takes some custom fitting to get it to not rub.
Honda s*** the bed on that one
116,520
I was thinking the same thing but been a while since I seen one on here and a complaint. Probably why lol.
That was one if the reasons I went with a soft mid panel
dweber23tr
245
774
Minnesota
My 1000-5 did this since day 1. Day 3 I used a tin snip and cut off the extra tab on the bed side that was sticking out. No more rubbing
thatguy2
988
8,208
Kansas
Mine is Honda Oem, Honda installed, and rubs. Just the way it is. My bed also rattles like a mofo and is annoying as heck.
116,520
Have you done the bed rattle mod or not yet?
Post #3👇🏻 If you havent tried it yet
Reactions: GovtMule
WagginTail
WagginTail
1,641
6,023
SC
Here's an idea long as you don't raise the bed often
20230718 123627
Reactions: Remington
