WTH was Chevy thinking??
Yep light duty
Couldn’t find the “Don't put your peter pumpers where you wouldn’t put your peter” safety sign so this will have to do.
477AA00C 8B93 412D ABC0 6B6ACD7E888B
What about the older ones in buses
I have a correct A-545 in the shed. Its a beast but I suppose you could shoehorn it in and would be ok in a 2wd. Works good in our bus.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
really? try google.you do know the rockies pass thru bc too right? spend alot of time at 14k,do you?[/QUOTE
If you are pulling 14K loads on steep mountains with your gas engine, you are working the hell out of it at high RPm's, I like torque and low RPM
Could always do divorced transfer case
That front driveline would be long puppy.
Reactions: BWAF
ehart814
ehart814
1,701
3,889
NWPA
Anyone here bought a new ford pickup in the last year or two? My friend did and as soon as them temp gets below freezing the doors won’t latch shut. Slam them all u want and they just bounce open. Summer now, so out of sight out of mind.
He took it to the dealer when it was just a few months old. they said Ford came up with two fixes for the problem and neither one works. LOL.
So he’s still driving the truck...soon he will be out of the lemon law window. So dumb. I would have screamed bloody murder until they bought it back!
How is that not a huge safety issue / recall?
Meanwhile, my ram truck has paid me back around $7000 tax free due to a problem that took them a while to fix, and FCA allegedly fudging the emissions testing (they never admitted it), and they gave me 8 years / 120,000 of warranty. I think I’ll stick with Ram for my next truck whenever my warranty runs out. :)
Mopower58
Mopower58
Unburdened by what has been!
88,331
755,886
Crystal Springs,Ms.
The big buses like inner cities have an Allison V-730 in them. I went to school in Indy on those. They basically have a ring and pinion in the front right behind the torque converter as to angle into the differential because the engine sat sideways. The Allison 540 would be a good candidate for a smaller diesel. We used to have all kinds of problems with them behind 3208 Caterpillars. The Allison 540 is electronic free. It has a governor and adjustable shift springs. It is basically a beefed up Turbo 400.
Mopower58
Mopower58
88,331
755,886
Crystal Springs,Ms.
No to deleted and tuned, only thing not OEM is front bumper and winch. Replaced the CP4 pump at 232k miles, other than that just regular preventative maintenance.
Do the fords have an in tank electric fuel pump to feed the CP4? Back when the Duramax had a CP3 they did not have an in tank pump. The Cummins with a CP3 did.
Reactions: VaHillbilly
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
Same with me, I just don't like to fix things until they are broken.
283,531
Yes there is an in tank low pressure fuel pump feeding the CP4 and a return line back to the tank for the excess fuel that the CP4 doesn't use.
They aren’t any better up close! Couldn’t find any angle I liked this truck from. Even the interior is behind and just blah.
I liked the looks of the ‘18 but this thing...
289CC7F4 65AC 4243 9FBE 1D31C5A6C6A9
VaHillbilly
VaHillbilly
NTC immigrant gardner
5,864
51,201
Sw VA
I agree I liked the 18 back to a 15 I believe it was.
Saw this fiat today at sheetz, not sure the year but it cant be more than 5 years I wouldnt think and the rockers on both sides were shot!
20190725 114952
