Mini Trail Mark
Mini Trail Mark
50
311
Where did you get the camo doors?
They are Honda Phantom Camo doors from the dealer 3EF619A3 B67E 4B8D 8375 390F61A76079
Mini Trail Mark
Mini Trail Mark
50
311
Thanks. I will check with my dealer. Are they real expensive? They look great. Do you like them?
Overall I like them, not crazy about unzipping window to reach in and open door from outside, but they are solid, easy to clean and match body panels well. As for cost, I think they were around $600 but I got discount at time of machine purchase so I paid close to $400. Hope this helps 😃
waynester
waynester
254
1,250
Ga, USA
Got her back from services. Happy with both front and rear bumpers and arm guards, happy with superatv 3500 winch install and very handy quick release bed rails. NOT happy with superatv full skid plate installed as per instructions 6 bolts stick below skid plate 3/4+ in. directly behind front wheel, obviously a big problem...20220507 101232 resized20220507 101212 resizedInbox 4 521 waynester58 gmail com Gmail20220507 103005 resized20220507 103023 resized20220507 103126 resized
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
Got her back from services. Happy with both front and rear bumpers and arm guards, happy with superatv 3500 winch install and very handy quick release bed rails. NOT happy with superatv full skid plate installed as per instructions 6 bolts stick below skid plate 3/4+ in. directly behind front wheel, obviously a big problem...View attachment 333121View attachment 333122View attachment 333123View attachment 333124View attachment 333126View attachment 333127
Can the attachment hardware be installed reversed? Can the button heads be installed on the bottom side?
195,048
My StrongMade stick stoppers have the same condition, U bolts that come from the top. I cut the remaining threads off with an angle grinder.
The Green Goat
The Green Goat
2,409
17,741
yard machines there not! trailer behind the riding mower=much easier on the lawn. go as smooth of rears you can find for kinda good results.
Today my 520 put in a solid 10hrs doing yard work and moving firewood / love this thing but need some turf tires!
Yup, I've had the same problem with turfing, especially since I stuck the Supergrips on it.
I still have my stockers, which I've been considering putting them back on, clamping the rear brake line, and then going out onto the road and doing a massive burnout until they are bald.
-or-
Buying a set of ITP Deltas and then putting a set of 25" Kenda Speed racers on all 4 corners. That's about a $600 option though, so I haven't went that route just yet.
Screenshot 20220508 1338012
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
X2. Can you get a socket wrench above the skid plate? That’s a recipe for problems as-is. I’d rather not have the nuts projecting with a shorter bolt. Send a picture to manufacturer and ask whiskey tango foxtrot.
hallic
hallic
320
1,795
Central MN
Took the plow off, respooled the winch line. Installed dual-voltage monitor.
PSA: Behind the dash on the drivers side, there's alot more bracketing holding things together VS the pass side.
But you know what they say when adult beverages are involved, Measure once, cut four or five times till you make it fit!
PXL 20220508 203113038MP
Hacked up a thin piece of plastic I had laying around, perfect fit!
PXL 20220508 210241368MP
