P1000 Transmission shifting hard
Mimbs15
Mimbs15
15
24
Jax Fl
Alright let's see if I can sum it up. 2020 Pioneer 1000 prolly about 5500 miles give or take. Here recently it started shifting hard at times, sometimes it won't. It would shut off sometimes while downshifting amd throw code 62. I went in and changed the shift valves and the dual clutch shift valve. Seemed to fix it about 2 weeks, started shifting hard again hit or miss. Mostly once it got good and warm. Now it's shifting hard majority of the time even at low speed. So I just replaced the 3 shift solenoids. Same problem. I just a
Reactions: TxDoc
Hello_Darkness
Hello_Darkness
361
1,587
Just to the right of nowhere
Have you checked the grounds, more specifically the one directly next to the starter.
Be sure to put a wrench/socket on them, as they can seem tight then loosen with actual force applied.
If that doesn't fix it, it may be the larger PC solenoid in the valve body.
Mimbs15
Mimbs15
15
24
Jax Fl
I have not checked the grounds but I willl.ck that one 2mor and the others. I've had the valve body off, what is the PC solenoid?
Reactions: Rayger143
Hello_Darkness
Hello_Darkness
361
1,587
At the top of the valve body is a large solenoid that comes in from the side, that is what applies the clutches.
Usually that code isn't a symptom for when it goes bad though
Mimbs15
Mimbs15
15
24
Jax Fl
That may have been the one I replaced then. It's kinda of on top of the shift valves. If it is that's the dual clutch solenoid
Hello_Darkness
Hello_Darkness
361
1,587
There's 3 smaller ones at the bottom that move the valves/oil around
The large one at the top actually controls finally oil flow/pressure to apply the clutch
Mimbs15
Mimbs15
15
24
Jax Fl
UPDATE! After the 3 new EOP sensors or shift solenoids that are located on the bottom side of oil pan. Shifts even worse. Whole slowing down and as it downshifts when it hits 1stbut will die amd throw code 62.. I'm at a loss.. Help Greatly Appreciated
  • Wow
Reactions: TripleB
Mimbs15
Mimbs15
15
24
Jax Fl
I assume noone has this issue.. this thing is kicking my butt.. help greatly appreciated
