Starting x4 build
G
Georgiaboy
185
719
Why did I have to use spacers to make them aligned?
All my new wheels are 4+3, so I can rotate them, when using the same size wheel you have to put 3inches of spacers on back, 1.5 on each side where the back will stay as wide as the front, the 4+3 on front is going to actually widen machine 3 in., Factory rims are 4+3 on back and 6+1 on front, but you cannot rotate them,
F
Firedad
46
103
Reno, NV
I knew that. Oh I know what the answer is to my question. My tires are same width vs stock rear being wider. That’s why I have rear spacers. Never mind
G
Georgiaboy
185
719
Wheels and tires installed, also installed 1.5 spacers on back, will get some pictures in daylight tommorow, machine is now 67in. in back and 68in. in front
IMG 20220923 203830265 IMG 20220923 203631621 IMG 20220923 201428531 IMG 20220923 201307242
JenElio
JenElio
81,411
710,658
Loxahatchee, florida
G
Georgiaboy
185
719
Lower doors came in today, they are not mounted yet, I just set them in holes to see what they look like, they are at least a 1/8in. Thick, very pleased
IMG 20220928 175407559
Reactions: Smittyp and JenElio
G
Georgiaboy
185
719
Worked ony lower doors a little bit today, got 1 side mounted, love the thickness and how they made but I will give fair warning to anyone buying the tusk, front mount up perfect just like directions, the rear have to be altered a good bit to work, tusk needs to look into that😂, we use to making things work, so we engineered it,
Was messing with some color on them to keep them from being solid black, made some designs, don't know if I'm gonna leave them or not, what y'all think
IMG 20220929 201040952
T-Rad1
T-Rad1
Tennessee
  1. Talon X4 LV
Nice looking graphic! Available in dif colors?
G
Georgiaboy
185
719
I made them on my cricket machine😂, was wondering if it was too much on there
