P500 Snow Plow recommendatons for P520
John Mc
124
276
Vermont
For those of you using a strap on your plow: does that replace the synthetic cable on your winch, or is it somehow added in addition to it?
If it replaces the cable, how time consuming is it to swap them out. I work in the woods in the winter, and will need the winch occasionally. (I'll be swapping in an unheated shop, but it's partially underground: it gets cold in there, but not quite as cold as it is outside.) The only winch cable I've ever changed is the 3/8" diameter, 230' steel cable on my tractor's 3 point hitch logging winch. That one is a pain in the butt.
The Green Goat
The Green Goat
2,414
17,791
A few more questions:
Poly vs steel blade: I'm leaning toward a poly blade, but wondering if these will hold up for light grading of gravel driveways, or do I need a steel blade for that? I have a tractor with a box blade for heavier grading duties, but that blade does not angle. Using the plow blade on the P520 might be better for bringing material back in from the edges of the driveway.
Plow Level Kit / Lift Kit: With the 27" tires I'm wondering about blade geometry and clearance. If I go with the KFI, does this mean I'll need their 2" plow level kit (or if I go with a Denali plow, do I need the standard push tube with 2" lift kit?). Is clearance between the blade when fully angled and the tires likely to be an issue? (Radius of my tires is about 1.5"
Installation: From the description, these seem to be pretty simple to do the initial installation. Am I missing anything, or is this all pretty straightforward
The poly is plenty strong. I've pushed dirt and a log brush pile around with mine with zero problems. Last I checked, I think a replacement poly face was like, $50 should you somehow manage to break it. The reinforcing frame and cutting edge are all steel.
As for the level kit, I think I went with the 2" for mine, which also has 27s.
Reactions: Jerryg and John Mc
The Green Goat
The Green Goat
2,414
17,791
Strap replaces the rope. On mine, its kind of a PITA to route the strap under the pulley as the metal end on the strap won't fit under the pulley without removing the pulley first. Pulling out the winch rope is straight forward enough, but mine uses a ball bearing to lock the rope into place and it can be tedious trying to get it back into place. I've only ran mine for 2 winters though, and mine stays on for the whole season, so its not a huge deal. If I had to take it on/off frequently, I'd come up with some better solutions.
Scoop
Scoop
5,408
21,283
  3. Talon R LV
Winter setup (winch rope, strap, etc.) goes on in the fall and comes back off in the spring. I would not want to swap back and forth throughout the snow plowing season.
Reactions: John Mc
John Mc
124
276
Vermont
Thanks for the feedback. The comments here that it can cause wear on the winch rope had me thinking strap, but the need to do some winching during the plowing season makes me think it would be simpler just to plan on replacing the winch rope more often, rather than having to swap back and forth during the winter.
Reactions: Scoop and Jerryg
Jerryg
Jerryg
12,251
96,698
NEPA
The synthetic rope on my Warn XT25 lasted about 10 years before it broke.
But it was a 54" Warn plow.
Reactions: trigger and John Mc
195,370
Mine lasted about 4 or 5. Went to a strap last yr. It's a pita to switch out plus I swap the fairlead from hawse to roller but it's a better setup for the repeated short area the line gets worked.
John Mc
124
276
Vermont
Sounds as though they should be using larger radius pulleys?
Did your your winch line set up have the extra pulley to cut the speed and the load on the winch in half, or is the line just a straight run to the push tube?
195,370
KFI doesn't use the pulley system and I didn't want one honestly. It's just another mechanical part to freeze up or bind IMO.
Reactions: Jerryg
John Mc
124
276
Vermont
Reactions: trigger and Jerryg
Splorin
320
904
Maine
Wondering if a silicone grease on a couple feet of the line used for plowing would extend the life of it??????
195,370
It looks as though they offer it as an option. Here's a link showing the set-up for the strap (the winch line version is similar):
Interesting, didn't know KFI even offered that. Would definitely make it easier on the winch but it's only a couple hundred lbs and (as fun as it is?) wouldn't want to slow the process down. It is cool though. :cool:
john790
399
1,154
Clinton ohio 44216
While wire rope is not popular on here thats what i run.For what you want to due might be a good choice BUT mine breaks about once a year.Easy fix cut off start over.Some say you dont need a pulley but for a gravel drive its a must.On blacktop or concrete maybe not needed.Tried both ways for me its a pulley.Made my own setup.Big pulley deep groove.
K
Kilroy
I just swap out the synthetic rope for the plow strap when I have the snow plow mounted. It only takes a minute or two to swap them out.
John Mc
124
276
Vermont
Thanks for all of the tips and advice here.
I'm ordering a KFI 66" poly blade set-up on Monday. I'm going with the strap. Hoping I won't need to swap back and forth between the strap and the synthetic winch cable too often during the winter. If it becomes too much of an issue, it's not that expensive to switch a couple components and use the winch cable for the plow as well.
It turns out a motorcycle/ATV/UTV dealer in the next town deals in KFI products. They have quoted a decent price, and the owners also happen to be friends from long ago.
Tom_C
Tom_C
158
473
Virginia, USA
Sorry to go sort of off topic, but I have a warn provantage front mount bracket, and wondering if the KFI blades the same mount pattern?
Jerryg
Jerryg
12,251
96,698
NEPA
Not likely but who knows, maybe with a small amount of modification it might.
