I just got a chub!When he shows up with a Devel Sixty he’s compensating.
Devel Sixty 6-wheeler shown in video ‘smoking’ a Mercedes-AMG GT
Just butchered a fat steer 749 pounds at yummy meat that's a replacement heiferThey both look delicious!!
Yeah buddy!! Sloppy Shelia..lolDoes she have a sister?
I don't think it's needed with my situation other than to help with tounge weight, which the airbags will solve the sag. 2000lbs of tounge weight give or take. I've ripped this up the interstate with no load on the front and never had sway. Adding weight up front won't create sway,actually the opposite. What I don't care for on the sway bar set up? And I've basically have the best one the husky. It hurts your turning radius alot. The bars are a pain to put on and off and down right scary sometimes. A guy I see at work from time to time broke his shin in half by one. So just want more user friendly in a nutshell .Why get do away with the WD?
Perhaps I am why?You’re not trying to compensate for anything are you?
I had the chain style but broke it reverse turn. Went with this setup. Mind you this price is just the head!I know it won’t help you since you are trying to get away from your w.d. Set up, but maybe someone else. I found to make it easier once you have a set go to link on your chain of 7the bar and have found the happy spot. I always would set the tongue down just enough onto to the ball to get it to latch, but not all the weight off the jack. That’s the time to throw the weight distribution bars on, It won’t take a 4’ cheater pipe on it to get it cam over and lock. They still are a pain sometimes, but better
So I had in mind using some of these but they were like 20 bucks a piece not too long ago. I just found these on Ebay and ordered several to try.Pretty much..i have an aluminum hinge. Tryin to find some push button fasteners or quarter turn thay i like..sometging like this maybe
I'll probably trip all over there frickin toys and give up the ghost!
I didnt.see them. All of the ones i saw like that were 20 bucks.So I had in mind using some of these but they were like 20 bucks a piece not too long ago. I just found these on Ebay and ordered several to try.
Black Universal Push Buttons Billet Hood Pin Lock Clips Kit Auto Car Quick Latch 692464666344 | eBay
It's hard I only have one left that doesn't know they grow up fastI'll probably trip all over there frickin toys and give up the ghost!
I know.. I posted the link. They ship via slow boat from China but for the $$ I’ll play with them and see if they’ll work. Even if I don’t use them on the storage door I’ll find some use for them.I didnt.see them. All of the ones i saw like that were 20 bucks.
Only problem i see with them is the diameter of the button. I dont think it will fit in the recessed hole the bolt was in. I may order a couple myself though..thanks for the link!I know.. I posted the link. They ship via slow boat from China but for the $$ I’ll play with them and see if they’ll work. Even if I don’t use them on the storage door I’ll find some use for them.
Yeah.. I figured I may need to do some cutting but we’ll seeOnly problem i see with them is the diameter of the button. I dont think it will fit in the recessed hole the bolt was in. I may order a couple myself though..thanks for the link!
