P500 Windshield, latest recommendations?
The one downside to the Honda windshield is the way they installed the rubber gaskets on the windshield...Mine kept falling off so I decided to gorilla glue them on....I figured by the time the gaskets wear I'll be ready for a new windshield...I was disappointed in the $$$ spent that they could have done something better there :)
Yeah, I lost one already. :(
I like the door in the middle. It looks like it opens to a secret garden. Certainly there's an English Tudor design element
Yep, the English were proud of their formal gardens.
Reactions: doolin64
SBuckJ
SBuckJ
214
216
Central PA
I had already glued the side gaskets on and this past summer I went thru a local water hole....and someone pointed out I lost the bottom one..twice....so the glue came back out-LOL
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
Yep, they either need glue/rubber adhesive or take them off. I took the side ones off and stored them. You really only need the side sealing if your are doing a full cab w/doors, ie snow plowing, etc.
That stinks!
You're probably right. Ok, I'll take my one off and store it. :)
NTC/TAP Transition Member
11,847
90,185
Thanks for the heads up, always good info from the membership. Wonder if silicone RTV works?
rocmar
rocmar
4,741
5,777
4 CORNERS
Go look under the accessories page. I just bought a full flip out. Waiting on it but it seems to be best of everything. For double sided hard coat lexan it was 266 shipped.
Hard coat
scratches'''''''''''
Plastic is better than
nothing....
Reactions: JTW
That's a good buy. I've had the hard coat for a thousand miles and I ride in very thick under brush. No scratches yet, you'll be pleased with it.
11,847
90,185
Yup, secret spot protected by Glock & Co!
Update, got the windshield and see what was said about wind and stuff coming in from back air flow, has me thinking about a rear cover. Also thinking about windshield film, had to put similar "security film" on new house addition windows by steps to meet code. It was a 3M product from glass shop and cost $60 for a 60x36 inch piece, squeezed on with water. Any better suggestions?
Heads up. Tried the 3M security film, did not look too good and was softer and likely prone to scratches. Read how the adhesive dries and has to be removed with razor blade cuts, so I quickly removed and trashed it. $30 wasted. Sticking with the uncovered hard coat for now.
Reactions: JTW
Road Warrior
Road Warrior
72
163
Palestine, IL
If I knew then what I know now, I'd have saved the $600 on the hardcoat windshield, made a steel frame and put regular auto glass in it with a gasket. The plastic/lexan sucks when it get scratched and even when new driving into the sun is nearly impossible during late evening hours.
Reactions: 100Acre and JTW
11,847
90,185
Just read old thread about using tempered glass from glass shop. I recently had a shower door made with holes for hinges. If I use my Honda windshield as a template, the flat part would be around $225 if the Internet price of $25 per square foot is correct. Could use same bolt holes to join the upper and lower curved sections??????
Road Warrior
Road Warrior
72
163
Palestine, IL
I just posted this over on that thread - Tempered glass is like a side window in your automobile. Your front windshield is laminated glass - 2 pieces of glass separated by a plastic film that bonds them together. Laminated glass doesn't shatter in a million pieces when it breaks. Keep this in mind when planning a windshield. ;)
I don't know what the options or requirements are for drilling laminated glass but tempered glass is drilled (obviously frequently) for multiple applications. Again, tempered glass shatters into millions of pieces and fragments. I personally wouldn't use it for a windshield.
Reactions: ChungasRevenge
11,847
90,185
Yes,Good point, just saw flat laminated glass (school bus windshield type) at $22 per square foot., Tempered around $25.
