Talon Weird Talon factory exhaust outlet/spark arrestor position
cummins14
cummins14
31
56
GA
We purchased a pair of Talons, my wife bought one and I bought the other actually. I immediately noticed that one had the exhaust outlet positioned differently from the other one. All of the other units they had in stock had the pipe pointing straight down toward the ground between the rear tire and the plastic muffler shroud just like my other machine. The odd unit had the pipe pointed out and kinda up from the vehicle as pictured. I guess someone on the assembly line was playing around ?
MFG
MFG
191
293
East Texas
I saw another picture of one like that on this site. I thought they just moved it to that position. Maybe not?
cummins14
cummins14
31
56
GA
I actually think I like it better this way as the factory position could possibly add heat to the right rear inner tire sidewall. I checked the heat and it doesn't affect the plastic muffler cover, so I ended up changing the other machine to match this one. The only issue I could see is that water could enter easier than when they are turned down. Most of the aftermarket exhaust systems turn the exhaust out the back at some type of horizontal direction.
Yeah that's definately an assembly fail and a dealer prep fail.
Its places like this that make every dealer look bad.
Reactions: nm6r
CostaRicaTalon
CostaRicaTalon
45
165
Costa Rica
I’m late to this party. But I’m actually thinking about trying it in this direction. Facing out. In dry season here our dirt roads get EXGREMELY dusty. And I notice if I’m at high rpm (which is almost always in the talon) I’m kickin up SO much dust. And I’m definitely not spinning tire.
Pretty sure the downward exhaust is just creating a dusty mess at high rpm.
DRZRon1
DRZRon1
1,404
4,335
most run a flexible steel exhaust hose from the muffler exit to the roof to cut down on the dust generation.....:eek:
Reactions: CostaRicaTalon
lowranger
lowranger
550
2,906
Northern California
I think I kinda like it turned out that way. Like CostaRica Talon mentioned on dusty roads kicking up more dust, plus, I think I saw on here somewhere that someone else had it turned out and it made the Talon a little quieter. I might have to try it.
Reactions: ChadD
DRZRon1
DRZRon1
1,404
4,335
be super careful backing those bolts out - if ya didn't anti-sneeze them from new - most will snap and a 2 minute job turned into a pita......good luck
Reactions: ChadD
CostaRicaTalon
CostaRicaTalon
45
165
Costa Rica
Thanks for the heads up as well. I got the talon used so I’m going to assume there is no anti-seize of the bolts.
I’m going to start using some penetrating spray for a day or 2 and heat it up to hopefully get those bad boys out easily.
