I'm at work now. Figure it will be back on by 9 this morning.
But it’s a humid coldAt least it’s sunny View attachment 414634
It's hard to believe we are warmer than you. Well, not right now, it's 20,We'e had the thunder storms move through about 3:00 AM, temps were in the mid 40's, temps now are mid 20's. Snowing, we're in that two hour window to see if ice forms on the roadways. Looks like we won't be above freezing for the highs until next week. We're going into hunker down mode, bird feeders are full, got fire wood, propane and groceries.
Could be worse, you could be in Calgary with-35. My buddy was supposed to go to Palm Springs yesterday but the flight got cancelled because it was too cold. Sunday now maybeAt least it’s sunny View attachment 414634
You sound like you're living in Calgary.Thank god for a buddy with a heated garage and a lift. Also thank for Chevy for a bad design and having a TSB that was easy to find and understand. Its bitter cold out here. I am seriously considering adding on to my shop and putting in a lift and spray foaming the whole thing for extreme cold and heat. In the single digits right now.
Spray foam is great insulation, but if it covers wood and a water leak ever develops, any damage/rot will be hidden for years.Thank god for a buddy with a heated garage and a lift. Also thank for Chevy for a bad design and having a TSB that was easy to find and understand. Its bitter cold out here. I am seriously considering adding on to my shop and putting in a lift and spray foaming the whole thing for extreme cold and heat. In the single digits right now.
Defund the Police. Maybe pitch those assholes spewing that smack in the pond?Just watched a body cam where a (hero) woman Vermont State Police officer saved a small child, submerged after falling through pond ice. Did not know body cams worked under water.
Agree 100%Defund the Police. Maybe pitch those assholes spewing that smack in the pond?
The football game tonight looks like it's going to be-24. The guys from the south aren't going to like the weather so much. On both sides.Currently 6 degrees and that is the high. It will fall through the afternoon. Nw wind 15 to 25 with high gusts. Dropped the ice eater in the pond after chopping a hole. Its several inches thick.
Yeah that's one disadvantage.Spray foam is great insulation, but if it covers wood and a water leak ever develops, any damage/rot will be hidden for years.
