P1000 Switches install
Commander
9
25
Does anybody know how to install switches in a 22 1K5. Have a light bar I need to mount the switch in the dash.Don't know if I will have to take the dashboard out.
Jankyeye
Jankyeye
882
4,182
Tampa, Fl.
No need to take the dash apart. You can see the back side of the acc switch plates with the hood removed.
Reactions: Commander
I always just run the wires through the switch hole, hook them up and push the switch in.
Easy way to test before you install the switch as well.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Are you going to be removing a rocker switch blank (plastic snap in cover that you remove to reveal switch hole), or are you cutting a new switch hole?
No doubt you will want to use the rocker switch to apply power to energize a relay, which in turn will then switch power to the light bar, unless the light bar is relatively small. The rocker switches are supposedly rated for 20 amps, though that's more than a stretch.
Commander
9
25
Removing a blank there are 4 blanks in my machine 22 1k5
bumperm
bumperm
1,921
6,820
Gardnerville, NV
On my '21 IK5 SE, there's a row of blanks as well. Behind that were 3 pre-wired switch sockets for adding (IIRC) wipers etc. They were not even wired for illumination. I just abandoned them in place and ran my own wiring, including lighting for the switches.
StewB
StewB
766
3,548
Agree with the above.
If you need more or want a switch at a different location, check to see what's behind the plastic.
For example, I'm right handed and wanted my turn signal switch on the left. I popped the cup holder and found a spot to the side.
Point is, make sure you have switch and wire depth clearance before cutting plastic.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Along with what @StewB said, I think it good to do any "major" panel fixes first . . . liking getting rid of the inane warning "You're All Gonna Die" placards first. This both opens up panel space, allows for behind the panel access for wiring and to make sure projects won't interfere with the mechanicals etc.
20210826 203158
20211217 210936
MR_509_P1LE
5
11
Check out PBR Products switch plates.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
After my experience with PBR, I wouldn't do business with them ever again. They made an incorrect claim, saying their windshield extender for the stock Honda windshield would fit Honda stock flip up windshields . . . it did not fit my '21 1K-5 SE. . They changed their add, after my input, but would not refund my shipping charges. That, and the product was poorly made. I politely explained the situation, they still refused to refund all my money.
