P500 Softer springs for p500
Steve00
Steve00
64
91
Florida
Hey gang! I just canceled my order for Walker Evans shocks. I couldn't stomach $1,200 for what seemed to be the only shocks available for my quad. Has anyone had luck with any other brand of aftermarket shock and getting a smoother ride from it? I'm just looking for a budget solution to get a slightly smoother ride. Personally I would rather just replace the Springs with softer Springs has anyone had any luck.
Rustell
Have you dis-connected your sway bar yet... ? This will improve your ride somewhat.
NTC/TAP Transition Member
11,880
90,564
You may have already tried it, but lower psi on larger diameter tires helped some. Sway bar removed amd spring preset to lowest. Slow rider.
70Bones
70Bones
888
3,779
New Brunswick Canada
Just a caution on softer springs... if you hit a rock or sharp bump at speed, it'll bottom out hard, and you'll get seatbelt burn...
WillyBill
WillyBill
Wheeling Addict
479
1,904
Clinton, Utah
  1. Talon X LV
Wheel spacers will "soften: the "apparent"spring rate significantly as well if you don't have to meet the "50" standard. PS...you can space out a bit anyway and stay "Legal".
WB
Reactions: Nashby
NitroxDiver
NitroxDiver
488
918
Concord NC
Wheel spacers and taller tires are the easiest way to make it ride and handle better.
Reactions: Nashby
GRANITE
GRANITE
People Dying to come see me!
1,627
9,515
Brookville, Indiana
Often times budget doesn’t mean comfortable! Whether talking shocks or airplane seats! :D
JCart
JCart
895
2,024
Kamloops, BC Canada.
I’d check out the air shocks If you like DIY projects. As mine is a work machine primarily, I went with the ELka Stage 3s, not entirely sure how they compare with WEs (you had on order) but they do ride very nice. Lastly I installed radials on mine last fall not driven a huge amount but smoothness, traction and is very noticeable.
j
Reactions: Nashby and trigger
pFive
pFive
670
1,264
Greenwood IN
I have Air shocks on the front of mine, they soak up the bumps and have eliminated harsh feedback on the front end.
Nashby
Nashby
75
285
83644
I don't have aftermarket shocks yet, but I agree bigger tires and wheel spacers make a huge difference in ride quality. I have 2 in spacers and 27 x 8.5 x 14 tires all the way around. Definitely a noticeable difference in stability and ride quality!
