Since I’m using my secondary fuse box for fused power where’s the best place to run the #2 wire off the rocker switch. Thanks again for all your helpYup welcome to forum
A separate fuse from the relay, probably won’t need much for the switch to control the relay maybe a 2amp fuse at most, but if it’s split going to the other switch too then you’ll need to account for what it will draw.
Will there be a spot on the relay that’s not being used? Or do I double up one of the wires that’s already going to the relay?A separate fuse from the relay, probably won’t need much for the switch to control the relay maybe a 2amp fuse at most, but if it’s split going to the other switch too then you’ll need to account for what it will draw.
Ok so I still have to send power to #2 on the switch from a separate source. Should I run a seperate wire from my auxiliary fuse box to #2???? No....
Ok great thank you again for all the help! I just want to make sure I get it right and not burn down my Honda.. lol
Made up a diagram from our conversation. When u get time can u check it out to make sure it’s correct. Thanks
