Pioneer winch mount kit installation; help with sub harness connection to accessory socket
MendonFam
Mendon, NY
I am installing the Pioneer 1000 Winch Mount kit. In their instructions, it says to "Route and connect the winch sub harness to the accessory socket as shown."
Is the accessory socket the back side of the accessory power socket, or what I like to think of as the cigarette lighter? Or is there another accessory socket that I am not seeing?
If the accessory socket for the cigarette lighter is the correct socket, there is already a connection there. If I unplug that current connection to add the new wire, I would imagine that disconnects the accessory power socket. Is that supposed to reconnect somewhere? It doesn't seem right that I am disconnecting that accessory power socket from future use.
I appreciate the help.
Screenshot 20221127 102415 Samsung Notes 20221127 100852
68,239
If you have the OEM Honda harness... Then it re-connects back. Like a in-between T-Harness.
Similar to how we make our key-on power harnesses.
MendonFam
Mendon, NY
You saved the day! I logged WAY too many hours attaching the winch, but most of it was stuck at this step. Your guidance is appreciated - thank you!
