P1000 P1-3 trail, factory offset
Jason W
Jason W
The Ginger Cracker
1,281
10,777
Western NC mtns, Marion
  1. Talon X LV
What would the factory offset be on my machine, or closest too, and im thinking 1.5 spacers + factory wheels is eqaul too what??
Reactions: Backwoods
JenElio
JenElio
81,024
708,872
Loxahatchee, florida
Not 100% sure but I believe the factory is 6+1 up front and 4+3 at the rear. Don't recall the factory width.........63" maybe??
Jason W
Jason W
The Ginger Cracker
1,281
10,777
  1. Talon X LV
So what would be the correct match for front offset to rear offset. If I would ditch the spacers
JenElio
JenElio
81,024
708,872
I'm not following?....... the offset I mentioned is the "correct" offset. If you want to go after market all 4 corners equal the most popular seems to be a 5+2 offset with a 1" spacer on the rear. That gets you close to having same track again. Otherwise your rear width will be narrower than front. The P1K has a narrower rear than front from factory, hence the 4+3 rears vs 6+1 fronts.
Reactions: Jason W
Mopower58
Mopower58
Unburdened by what has been!
86,557
747,114
Crystal Springs,Ms.
I got 5+2’s on all 4 with a 1” spacer per side just on the rear. Never measured but it’s not noticeable if the front is wider. I have 28”X11”X14” on the rear and 28”X9”X14” on the front so that might be the difference.
IMG 0341
WagginTail
WagginTail
1,641
6,021
SC
@Jason W this site might help you out. It did for me when getting aftermarket wheels for my wife's 4runner. Wheel offset calculator
Also I have stock wheels on my Pioneer 1000-5. I got the widetrack bundle from RB3OFFROAD and I like it. I think this makes the rear tires slightly wider than the front but I like it that way
Hillbillytnt
Hillbillytnt
559
2,053
Ky
I’m not sure about newer models but my 19 came with 6.5 inch rims in the front and 8 on the rear. Neither of those can be 4-3 or 5-2 because they aren’t 7 inch rims.
Jason W
Jason W
The Ginger Cracker
1,281
10,777
  1. Talon X LV
I dont want to do all the same size width, I like a narrower front tire, and plus I can still rotate side to side to prevent tire cupping, I don't run directional tires
Reactions: JenElio and futzin
