P500 My P520s day of reckoning
crewcabrob
crewcabrob
1,029
4,041
Omaha
This is a teaser photo for a different setup I’m going to run at some point.
the two boxes on the right have new beadlocks
E2921156 D620 4E26 98B4 0C81F3D867D1
crewcabrob
crewcabrob
1,029
4,041
Omaha
I moved my new set up to my basement so I could work in a warm space. Cold tires don’t like to slide on wheels very easy.
Here is a quick shot of the new rubber and beadlock wheels. I hope to work on them tomorrow.
4088A9B9 744A 413A BE30 F26771CAFFF0
The Green Goat
The Green Goat
2,363
17,449
Godspeed on clicking your torque wrench 800x while sequentially torquing all of them.
pro tip: set the wheel over a 5 gal bucket so its elevated to a comfortable position and squeeze it between your legs to keep it from turning. that's what I did and it still took forever.
210,890
I used antiseze on every bead lock bolt, that will help slow the process down even more.
crewcabrob
crewcabrob
1,029
4,041
Omaha
28x10 Interco Snipers. 8 ply radials that are DOT marked. Tread is 3/4 of an inch deep.
I’m going here from 27x11 Bighorn 3.0 radials to these so I can get closer to 52.5” wide. My current set up is about 55” wide. To wide for 50” gates
Bad_bowtie
Bad_bowtie
Huge member
2,567
15,861
East Tennessee
A buddy of mine runs those Snipers on his RZR900. He really likes them.
crewcabrob
crewcabrob
1,029
4,041
Omaha
OK, a quick update:
I finally got all of the tires mounted over the weekend. That was a bear! I did my original set of beadlocks with no real issues, but these were way worse. The sidewalls were so stiff, I had to go to the hardware store and buy longer bolts of the same size and pitch just so I could get something started. After I got for of the longer bolts in and snugged down the beadlock ring, I could then go back and install the regular hardware.
Used a bucket to rest the wheel on and anti-seize on all bolts. Still have to go back and hit with the torque wrench, but have a little time before I can mount the wheels the Pioneer.
I inflated one of the tires to 12psi and measured. I marked a spot on the ground and rolled the tire forward in a straight line until I go to the same spot on the tire. That measured 85" 85/3.14=27.07".
20230225 033659386 iOS
crewcabrob
crewcabrob
1,029
4,041
Omaha
Hopefully they work out.
I am expecting them to get me closer to the machine width I am looking for. I also expect them to be quieter than the BigHorns.
I'm not sure how they will ride. Reduced sidewalls from what I have now will marginally hurt. The sidewalls are noticeably stiffer, so I might have to run slightly lower pressure than what I'm accustom to.
Hopefully some time this week I can get it all sorted out. I might change the color of my plastic from Blue to either black, red or grey with wrap. Red anodized hubs and shocks would be fun with an all black look.
Rob
