P500 Mighty P500 Build
Description of my personal build. I started with a blank sheet of paper, let uncle honda build the basic vehicle then added the stuff that I didn't think of at the time, wasn't allowed to do or was too expensive for a entry level SxS.
208,144
Tires:
On my outing to test the front locker I pinched a rear tire.
I was riding with 2 experienced p1k pilots so I dropped the tire pressure to 6psi to gain a little traction.
By the time I got home one of the rears was noticeably low on air.
I could see where the pinch was but it was not bad, just a slow leak.
So I tried to patch it on the inside.
Kind of a pain as the side walls are curved and fairly stiff.
The patch leaked or there was another leak I did not see, the tire went down ever so slowly.
When my wife saw this she told me to quit messing with it and order new tires.
If I would have known it was going to be that easy I would have backed over a screwdriver the 1st week I had the thing.
I did a quick survey to see what size and tire I wanted.
Then I ignored this and got what I knew I would be getting anyways.
I know, I've used this picture a few times already.
But the tires look good don't they?
That must be one bad A mud puddle! HA!
The Green Goat
The Green Goat
1,892
13,781
I'm glad I'm not the only one over here scratching my head wondering how he managed to do that...
lee
lee
Village Idiot
2,367
13,357
Springfield Ohio
So, although I should know better I plowed out from the snowpocalypse using my synthetic winch rope and a hawse fairlead.
A) 5” of snow is not a snowpocalypse.
B) I’m a dumb ass.
As one would expect the rope broke, fortunately right as I was finishing.
Interestingly the rope was having an issue an issue with the center of the spool being crushed.
In the picture below you can see the V shape of the rope on the spool.
So I looked at some of the solutions that that the winch makers have out there.
$30~$40 is not bad.
But the reviews point out all sorts of issues.
Looking at YouTube I found this.
It seams to avoid some of the pitfalls and it’s cheap.
316822 1d3ae6e3892245c648d67972fd86391e
Bought a cheap tow strap from harbor freight, cheapest on they had was $12 and it will make 2 straps.
Used duct tape to attach the strap to the drum.
Spooled the strap on to the drum.
Also I switched out the hawse for the roller fairlead that came with the winch (the one with the big roller on bottom - looks like it has a fat lip).
The Warn/Honda plow has a thing to keep the hook / thimble out of the fairlead.
I folded the strap in thirds and it fit in the little catch thing.
Made another pass around the property and this set up worked well.
So far so good.
163,958
B) I’m a dumb ass.
$30~$40 is not bad.
So far so good.
Yeah, I started switching over to the roller fairlead after breaking my rope plowing. I'll use the hawse on the trails though.
The Green Goat
The Green Goat
1,892
13,781
FYI, KFI sells a plow strap for like $30, if you don't want to mess with making your own.
lee
lee
Village Idiot
2,367
13,357
Springfield Ohio
Dd3acbae e8a4 45d5 8a8b b9b71f0971f7 jpegIMG 3152
I've been threatening to do some kind of Milwaukee Packout storage thing for a bit.
The soft bags where fun but after 4 years and ~2000 miles they are showing there age.
The internal baffles are tearing, a few of the hold down straps are looking tired and the rear bag isn't holding it's shape - it doesn't close correctly and leaks.
So, I made a board, 3/4" plywood, cut to shape to hold 2 large Packout bases and one half size.
There is also a rack to hold one of my 5L gas cans, the rack is an army surplus ammo box rack.
Originally the ammo box rack was set up for 2 boxes side by side.
I cut it down to hold just the one gas can.
IMG 3154
I set it up so there is some separation between the boxes.
This allows the lower box to be accessed without needing to remove the upper box.
IMG 3153
So, on the left is a XL tool box.
This is used for holding rain gear (frog togs) and excess warm clothes for my wife, a heavy coat, Carhart overalls.
(and yes, excess is the correct word)
On the right there is a tool case with inserts on the bottom and a large tool box on top.
Originally I had them stacked the other way but the smaller box was way heavier, so it seamed logical to invert them.
The tool case has both tools and recovery gear.
I usually carry a canvas tool roll with a bare minimum of tools, my tool list is developed to fit the fasteners used on the p500 with nothing extra.
But with the bigger tool case there was more room so I went crazy and that thing got way too heavy.
I will have to show more restraint next time.
The larger box has snacks, first aid kit, binoculars (I keep bringing them but I have yet to pull them out to use them).
It's the general 'stuff' box.
IMG 3155
Finally I added a 16 qt cooler on the back.
We have been using a soft cooler in the soft bags.
With the hard side cooler we threw a bag of ice in on top of the drinks.
It was nice to have ice on the trail.
The board is held to the Mighty P500 rack with 8 of the honda 25.4 mm ROPS clamps.
This makes it relatively easy to switch between the cargo tray and the Packout plate.
At the Takeover I used the cargo tray to haul our gear up to the cabin, then switched to the Packout plate.
IMG 3152IMG 3156
Special thanks to @Neohio and @futzin I asked a lot of question before I did this.
And seeing @futzin mount some Packout on SpiderMonkey motivated me to get off my ass.
IMG 3151
13,636
68,254
@lee can you share the part number or pictures of the 25.4mm clamps? I am not sure I have seen them that small.
It does look good. You should enjoy it. I did see some other 500 with packout, but I wondered why they had the plates reversed. The latches were towards center. I wasn't sure why it was done that way.
futzin
futzin
3,610
26,513
Kentucky
Probably mine.
I mounted the plates towards the outer edges of the Honda tray, which has side walls.
I figured the walls may interfere with setting the boxes.
KyGal83
KyGal83
8,192
81,857
Kentucky
Add me to the “I need Packouts” list. Did someone say snack box??? Where?? I wanna see???
@lee loving your spare gas setup. Did it work well there? Any issue? Can you give me details on the tank & mount?
lee
lee
Village Idiot
2,367
13,357
Springfield Ohio
The 1" ROPS clamp was created to mount to P500 cargo tray to the rack.
So it has a 'HL5' part number, Honda part # 08L00-Hl5 -A01.
FYI, the cargo rack on honda ATV's are a different size so this part has really limited application.
A few notes on making the board.
The board is 3/4" plywood, holes where located based on the needs of the Milwaukee Packout base plates with T-nuts installed.
And the board was covered in Herculiner roll on truck bed liner.
IMG 3158
I wasn't really paying attention when I started applying the Herculiner.
The can said something about not shaking so I stirred it.
After coating one side of the board I flipped it over and ran out of goop.
Apparently you have to stir it aggressively.
I had half a can of rubber crumbs compacted in the bottom of the can and only half a coated board.
As I had left this whole project till the last weekend, and I needed to attend a wedding on Saturday I scurried around trying to find Herculiner on the shelf.
I found it but it was touch and go for a bit.
T-nuts.
I ordered all the nuts and bolts from Amazon (china).
The quality is s***.
The black 6mm bolts are rusted already.
The black washers are zinc plated silver and painted black - so the corners of the bolts wipe the paint off and you can see a ring of silver around the bolt head.
I dropped the T-nuts in the holes and knocked them in with a hammer.
But, probably 1/3 of the T-nuts where pushed so tight against the side of the hole I could not start the bolts.
I ended up knocking them out with a punch and inserting a longer bolt to draw the T-nuts in, then replacing the bolt.
I placed washers under the Packout base plates at each bolt hole.
The base plates have a T-washer to transfer the load of the bolts to the substrate the base plate is mounted on.
As I was using a soft wood the extra washer will spread the load in to the plywood board.
The 1/2 base plate do not have this feature.
I found this amusing, why dose one have good design practice and the other dose not.
Oh-well.
I need packouts. And we need some pictures inside the snackle box.
The snackle box is a nice size and it has several handles to make carrying it easy.
But I find myself garbing the aluminum corner braces.
IMG 3159
Inside the snackle box is a nice little tray that is always easy to access.
So this tray is stocked with trail necessities and important paperwork.
However the snackle box was packed by a male (as biologically determined by a trained medical professional at birth) so there is no port-a-potty or privacy tent.
Picture shows the contents sans snacks (post trip picture).
IMG 3160
Finally, the gas can holder.
There is not much to it.
Basic aluminum angle frame with a strap.
The strap has a hook on the side you cant see and an over center toggle device.
Gas can stayed put the whole weekend.
1718065182777
Scoop
Scoop
4,587
17,966
  3. Talon R LV
@Scoop which box are you using for your snackle box
This one: 48-22-8435
There is one that same size but half as thick that we filled with first aid supplies: 42-22-8436
Those fit nice on top of the smaller Packout cooler: 48-22-8460
