P500 Lawn mower battery as second battery.
Red500
Red500
6,606
70,962
Greeneville, Tn.
I purchased a battery for my lawn mower this summer and a month later the plastic transmission went out. I'm thinking of using it as a second on my P5. I know it's not the best solution but I've got it so I want to use it. What are your thoughts on this.
JollyJoker
JollyJoker
92
192
Minnesota
I used at lawn tractor battery (U1 340cca/45rc) for 3 years on my P500 and tied it in to my winch contactor and it worked great. If you already have it sitting around, you should use it.
NTC/TAP Transition Member
11,880
90,564
If running independent should be good. Only thing I’ve read is that 2 batteries on same charging circuit should be same specs.
Reactions: DaddyDubbs
1HasBeen
1HasBeen
302
761
Wickenburg, AZ
Use what you have, and when it's time to replace it remember a Rhino battery is the same size, and can be had in AGM with good reserve.
Red500
Red500
6,606
70,962
Greeneville, Tn.
Will that matter if I use an isolator.
Reactions: Mudder
Red500
Red500
6,606
70,962
Greeneville, Tn.
This one is a sealed led acid so not really worried about leaking. Plan to make a place under the driver seat for it.
Reactions: Mudder and 906UP
