P500 "I have questions" thread
hallic
hallic
320
1,795
Central MN
Take a look at the Bison. I was about to order a Strongmade but ran across the Bison that gives a lot more protection and I use stock Honda winch mount with it.
Ya, was looking at the Bison, but passed. Have their rear bumper which is nice, but I don't want my winch down that low for plowing and mudding reasons, lol.
I do really like the "full coverage" aspect of the Bison.
hallic
hallic
320
1,795
Central MN
Question for all the 5x8 and 5x10 trailer peoples (Or whatever else size):
Do you really *need* the ramp? 26" tires, I should be able to crawl up onto the trailer without a ramp, right?
Or does it bounce around too much?
The Green Goat
The Green Goat
2,440
17,965
Why size Stinger does one need to manage power for the whole system? Plan is to route all power, including winch draw, through this relay.
A Viper 6k is what I will be running. At max amp draw, Viper states its 330a draw on a 1st layer pull. Factor in some lights (~30a), Sound bar (?amps), and maybe a heater. Stinger makes an 80a, 200a, and 500a model. It sounds like the 500 is what I need.
Thoughts?
Reactions: Bigtee
Seadonist
Seadonist
380
1,117
New Orleans
If you’re looking for a bumper with a winch mount on top, check out the C-fab bumper
futzin
futzin
4,820
35,337
Kentucky
I have a 5x8 tilt trailer. If parked in a somewhat strategic spot, tilting not needed (27" tires).
Side note: this small tilt trailer has the axle located further forward than a standard trailer. Results in much more weight needed forward of the axle. With the P5 on there I get trailer sway, so I have to add weight to the tongue.
Therefore I don't recommend a 5x8 tilt trailer for the P500.
Reactions: CID and hallic
196,693
Thoughts?
FWIW...I'm running two 300 amp circuit breakers. One is dedicated to the winch and the other for all accessories.
hallic
hallic
320
1,795
Central MN
Thoughts?
I have a 300amp breaker, and the 6k elite widespool viper winch, along with some lights etc.
My thoughts were, light and medium pulls it should be fine, but if I have to do a REALLY hard pull, I'm going to double (or triple) the line with a couple snatch blocks so the winch doesn't have to work so hard.
I also carry a 20' and 15' tow straps, some shorter tree savers etc.
Reactions: trigger and Mudder
Bigtee
Bigtee
556
1,213
Grayson, KY
I plan to run my winch through a 300 amp breaker. All of my other accessories will go through a fused relay (won’t have to have a fuse block).
E8E08D87 E7C4 4074 A748 7AA2BDE9A4C7
The Green Goat
The Green Goat
2,440
17,965
Thoughts on 28x10x14 tires and rubbing? Looking hard at the Tusk Terrabite Aramids in this size. Per RMATV, the true size is 27.25". Will probably end up with a 1" spacer on 14x7 (5+2) wheels.
NTC/TAP Transition Member
11,885
90,617
I’m running 27s no issue. Maybe the spacers might give you some turn clearance. PSI also a factor on tire diameter. Lots of threads searching 28. Here’s one with a @trigger reply.
196,693
You might be alright with those unless you're running Ricochet rock sliders as they protrude into the wheel well a little. 26x11, 5+2 and 1" spacer rubbed the rock slider. Why 14's? I know it opens up the tire choices but doesn't leave much sidewall to cushion the ride.
The Green Goat
The Green Goat
2,440
17,965
Will probably end up with SSS full skids/arm guards as well as the Honda nerfs (know anything about those?.....)
As for the tires and wheels; my ideal size would be 27x10x12, but they unfortunately don't make it. I think I want the same size on all 4 corners for simplicity sake. 9s seem too skinny and 11s seem too wide. Also, there's the wheel selection aspect. I can't seem to find anything I like in a 12".
hallic
hallic
320
1,795
Central MN
2 Questions for trailering peoples:
1> Any recommended jacks for 5x10 utility trailer? Scissor VS bottle? or is a $20 harbor freight scissor jack good enuf?
Have a good one in the truck I can drag over and use if I need to, just looking for one to keep on the trailer toolbox.
2> Anybody put on trailer sway control for these little things? Trailer is max rated at 3000lbs, I might get over 2000 once in a while, but not very often. Was a trucker for like 7 years, so used to hauling bigger stuff, this is the smallest trailer I've ever hauled, lol.
