P1000 I bought a new trailer.
Jshell3
16' tandum axle with reinforced ramp built into the gate and cable assist. (Because it's heavy) lol
Fits my P1k5, and my MF135 tractor.
It's a 2016.
Bought from a guy who digs graves for a living. He bought a bigger trailer for his backhoe. He also needed trailer brakes. (This trailer has none)
Lucky for me, he had done all the welding to this trailer before he opt'd for a new one.
IMG 4036
IMG 4037
IMG 4038
IMG 4039
IMG 4040
popeye
popeye
3,275
14,644
kapowsin, Wa
You should be able to put brakes on it if you wanted to. Dexter the axle manufacturer welds the brake backing plate flange onto their axle tubes. You would just have to buy the parts and bolt it up and wire it in.
Corona1
Corona1
319
878
The Land of Cheese
Excellent advice. Especially when towing the tractor.
AZhunter
AZhunter
122
154
Peoria, Arizona
Very Nice! I have the same size trailer and the same type of tailgate/ramp, how does your winch/cable system work? Thx!
Reactions: Jshell3
popeye
popeye
3,275
14,644
kapowsin, Wa
Should be able to see if the flanges were welded on to the tube pretty easily. But might have to change your whole wheel hub assembly. I think the 5 lug is 3500lb. witch the hub and brake drum is all cast together as one piece.
Manwell
Manwell
803
2,439
Very nice and I probably need to take a look at one of the brake packages for my trailer as well!
Reactions: AZhunter
solrus
solrus
1,629
2,511
Montana
I am going to get new trailer too, once I buy tracks for p500.
Sent from my XT1585 using Tapatalk
Reactions: Jshell3
Jshell3
(Sorry for the late reply.)
The yellow tubes contain a cable connected to a powerful spring. As gate goes down the spring stretches. Lift assist.
