Help with my 2013 Jeep Grand Cherokee inspection. (not ready)
68,145
Went to go get it inspected and a small antifreeze leak checked on.
The leak turned out to be the thermostat and housing.
Paid to have it replaced because I don't have time to mess with it.
Along with a full coolant flush.
Anyways..
They tried to do an inspection but it was in "NOT READY" mode.
Why would it come up not ready when there has not been any check engine lights on?
Did the tech unhook the battery when doing the above for too long and made it go into NR status?
Drove it 20 miles today and I still have several NR.
Besides driving it another 20+ any other advice?
Thanks.
Reactions: Smitty335 and ChadD
21,712
92,801
Eric O made some comments on getting the vehicle "ready" in this video I believe.
Closer towards the end of the video. It all has to do with drive cycles, and how the PCM reads a drive cycle.
It may have been this video.
68,145
Currently on a 20 mile HWY loop run.
120828b8f522ca5cad0324ab2da3186f
Robobrainiac
Robobrainiac
2,671
9,280
I am not sure which scan tool you are using but depending on the PIDS available you may be seeing a list of non applicable status modes. Depending on your temperature outside it may take longer to achieve O2 sensor closed loop status. You may also need more drive cycles versus actual distance driven if your DTCs were cleared
210,954
That was interesting!
Reactions: Buggyman
43,567
So...if I'm reading that right, the EVAP and EGR are the only ones available that haven't run?
EVAP may not run until car is off and sitting for a while. Lots of newer stuff does this post-drive testing now.
As for EGR...is this a hemi? A 3.6 doesn't have an EGR system as far as I know (don't quote me on that). Service data...IE-Alldata, Mitchel, etc will often give the criteria for self checks for each system, usually.
Buggyman
Buggyman
47,882
375,855
ne. ohio
On my GMC I found info on the drive cycles on Google. certain speed for a certain amount of time then accelerate to a higher speed for a givin time then decelerate to a certain speed to shorten the amount of time it takes for the computer to relearn.
Reactions: Smitty335 and CID
Robobrainiac
Robobrainiac
2,671
9,280
Disconnecting the battery can sometimes reset the control modules and clear codes. Some mechanics may also clear codes as a precaution when messing with just about anything. As an example your leaky thermostat could have had a pending status code for temp not reaching optimum temp in a specified amount of time. Or over temp codes pending status. You will not get a MIL while the status is only pending. You don't want the customer coming back the next day with a check engine light on after a repair was made, especially for something you just fixed. So some mechanics may just do a wipe or clear of the modules.
