P500 ECU replacement
21,759
93,330
So is there a chance my Ecm is good and the wiring after is causing the short?
Correct. Something would have made the ECM go bad.
Can you post a pic of the ECM? you might be able to see the PCB for a bad spot.
rtn001
rtn001
317
945
Central Florida
If I remember my electrical trouble shooting 101 it just could be. I would do everything I could to make sure before I spent the $$$ for a new one. I had good luck with eday and Amazon parts for my Kawasaki. I would attempt to get a Honda part if it is to be had.
Gambled22
Gambled22
14
25
Ft.lauderdale
653B01A0 AE45 4BAD ABC5 2AA5D9C53C77 EBC6228A 500E 4345 8B12 63F1C8B73D38 CAC4E053 4ADA 467E 988C DF5A36F80F43
Gambled22
Gambled22
14
25
Ft.lauderdale
If water got into one of those connectors could that of caused it to just turn off while riding, and blow the fuse???
rtn001
rtn001
317
945
Central Florida
If water completed the circuit between the power lead and a groung yes it could blow the fuse. If you got water in a connector dry it with a heat gun or a hair dryer. Put dielectric grease on the connector. Plug it in and see if it blows. If you haven't done it yet you need to put dielectric grease in all the connectors. You can get it at any parts store. I get mine at Walmart in the automotive section where the head light bulbs are. They call it bulb grease. Just wondering. Have you checked to see if you are throwing any trouble codes? I don't know how it works but there is a thread on here about it.
906UP
906UP
15,055
143,083
da Yoop
It's highly unlikely to be the ECU, my guess is you've got a short in something that is energized by the ECU....fuel pump relay, ignition circuit, etc. The sealed units used in powersport applications rarely fail...it can happen but as others said, check everything else first.
Reactions: rtn001
O
oldfortyfive
608
1,386
Illinois
Don’t overdue the dielectric grease. It’ll hydraulically push the connector pins out of the housing.
Reactions: rtn001 and Mudwing
Eltobgi
Eltobgi
4,599
15,187
North Dakota
So I have been working on my 2015 P5 over the past week and removed interior plastics and floor and unplugged my PGM-FI (ECU) and set it aside on the work bench. Completed wiring to support dual battery and turned my dual battery switch from Off to On to restore power to electrical. Tried to turn the key to check power and...nothing:mad:. Mounted the fuse block up front so checked for power and I had AUX power. Then checked stock battery where I extended power and ground and I had power. Hmmmmm
Sat there contemplating what I could have done wrong and then realized I did not have the (ECU) connected. So I grabbed it from the bench and carefully plugged it in and the turned the battery switch again from Off to On and then tried turning the ignition switch again and this time...
Power...Glorious Power:)
So I told this story after reading the last few posts about disconnecting it and the P5 still wanting to start.
Assuming they can’t start with a disconnected PGM-FI (ECU) as mine could not. I think this would indicate a short somewhere. What do you guys thinko_O
Gambled22
Gambled22
14
25
Ft.lauderdale
Hey everyone and sorry about the delay, i just got the ecm i ordered, plugged it in and everything works now, i am definitely going to make those connectors stay dry from now on and hit them with the grease. Just want to say thanks for all the help narrowing this down.. cant wait to have it out riding again in
Chooglin
Great news , glad to hear she's running again!
