P1000 Current Problems with your Pioneer 1000?
  • No issues.
    Votes: 150 68.2%
  • Minor issues.
    Votes: 39 17.7%
  • Major issues.
    Votes: 31 14.1%
  • Total voters
    220
It's just the way I am. I do that with any vehicle car or ATV. After a full inspection you'll be surprised at what you'll find.
You'll find problems with alignment or things not centered exact like they should be.
I don't think my local Ford dealership is ever going to allow me to bring a vehicle in there again. First of all, I never take my vehicle anywhere to get repaired unless the repairs for free like for example it's a warranty job. I had a warranty repair performed on my truck it when I got home I thoroughly inspected and found enough problems that the technician lost his job and the dealership was very sorry for what they had done.
I took my wife's vehicle to a shop a couple years ago to have a new transmission installed and I inspected it I made them take it back out and try again the correct way. And they did it without charging an extra penny and apologize for screwing it up the first time.
When I had a company owned vehicle, we had to use fleet services to keep the vehicle maintained. I would constantly rip them a new one because they didn't change the oil filter thinking I wouldn't notice or put too much oil or not enough oil in the vehicle. One time I inspected the vehicle after a break job and found out that the brake pads were installed backwards!
So Monte, I agree that you shouldn't have to do things like that. But it's what I've always done and it doesn't matter if it's ford Chevy Honda Polaris or anything else you always find mistakes. I'm just amazed at all the hardships I would've had in life because of vehicle failures if I had not performed my inspections.
Oh my, that's amazing!!!! The only thing that I would disagree with you on is in classifying all that as "mistakes". I'm afraid you actually discribe carelessness and an unsavory characteristic of human nature. Far too many people just do not give a #%€£! But see what happens if ever once, their paycheck isn't on their desk Friday afternoon. I'm an employer and I can tell you that most people are looking for a check, and not a job.
You're right. I expect the same from the guys that work for me. Sometimes they say I'm picky or too hard. @DGann !!
Just look it over real good when you get it. I will say that the white one was MUCH better quality than the red one.
Don't hurt my feelings like that Joey. :(
I should say that I bought the red one in 2015 and the white one a year later and the assembly seems to have improved.
Better?
Reactions: Plumber32
Better?
It was a joke, it's always good. ;)
Reactions: joeymt33
Sulli
19
21
Florida
List your current problems with your Pioneer 1000!
Problems: Yes or NO. Please list them.
  1. Which pioneer 1000 do you have?
  2. The date you bought it?
  3. How many miles you have on it?
  4. What accessories you have installed on it?
  5. The terrain you ride on?
  6. The brand of oil you use in it?
Here is mine:
Problems= back brake line was leaking had to tighten it and bleed brake lines. front end alignment because tires wear on the inside to much.
1. Pioneer 1000-5 Non Deluxe [Green]
2. December 30 2015
3. 1625 miles
4. HARD ROOF 5P, Honda ALUMINUM A-ARM GUARDS front & rear ,TWO-PIECE POLY WINDSCREEN (HARD COAT),KFI SE45 ATV Stealth Winch, ATV Tek UTVSV1 Adjustable Multi-Directional Sun Blocking Clear View UTV Sun Visor,Heininger 6000 Advantage Adjustable 11-Inch Hitch Extension, Home made mud blockers, Kolpin 3 Way Hitch, 2-Inch, Moose UTV Inside/Outside Rear View Mirror - 0640-0386.Rubber Bed Mat led light bar.
5. woods, field, back roads, Mud, Water, rocks, dirt. Ice & snow. Steep hills,pulling 5x8 trailer.
6. Honda oil
Problems= Bottoms out when you have two big guys in front when hitting significant bumps or jumps. Rear passengers get beatup pretty bad due to passenger position over rear tires. After pulling my son out of a mudhole at Hogwaller I think I burned up my clutches? Machine doesnt move until over 1000rpm and doesn't want to shift. Although Honda dealer service manager says problems due to riding in High gear. He says Honda recommends low gear? Would the Pioneer 1000 ride well at 35+mph in low gear on dirt and clay trails? Otherwise the design is good and have enjoyed it overall just frustrated with possible clutch problem.
1.Pioneer 1000-5 Deluxe Camo
2. November 2016
3. 600+ miles
4. Super ATV hard roof, Super ATV 2 piece windshield, Traveler 4500lb. winch.
5. Home/ranch use, fast trails Durham Town Plantation, Ga, Hogwaller Mud Bog, Fl. Mostly trail riding in dry sand and clay 35MPH +/- average speed.
6. Honda oil
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
2. November 2016
3. 600+ miles
6. Honda oil
It won't hit 35 in low. Has a speed limiter in low range. PITA too
Sulli
19
21
Florida
I didn't think so, kind of crazy that the service manager would have suggested that. I'm pretty disappointed, this is my first Honda(other than my mini trail when I was a kid) and I was looking forward to a very reliable machine. Dealer says they are warrantying a lot of clutches, not what I wanted to hear. I have Arctic Cat and Polaris machines for myself and my kids as well and haven't this kind of problem, especially this early on. Don't get me wrong the other machines aren't perfect but no major problems with years of riding.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Check it again, mine will hit the rev limit at either 35 or 36 mph in low.
Already been checked several times. Mine tops out around 32 or 33. Probably speedometer error.
Reactions: joeymt33
211,563
Are you hiring, Im looking for a employer who understands their employees?
Raymond2525
7
5
La
1. 2 axles broke passenger side less than 50 hours they broke when it bottomed out the wheels over extended.
2. rear passenger axle again went out , replaced it with turner eagle axle still working fine.
3. front axle right side again goes out , trying to get Honda to warranty it, they say it will take a week, to find out if they will or not.
4. rear door latch loose locking machoism .
5. I think it geared to high and Honda needs to fix this. why can someone in there shop can make a fix, and charge $850.00
were is Honda at on this. they cant give us a lower high range and lower low range we spend thousands for this machine
they can fix this for almost nothing. it will cost us about $850.00 and about $510.00 for each axle $2040.00 total $2890.00
Honda can fix it cheaper than their customers , then they will have a sidebyside.
sharp
sharp
3,757
14,955
Tennessee
Post pics of the broken axles. Just curious.
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Sounds strange! What mods do you have installed? Also pictures of your ride if you would? Thanks.
Raymond2525
7
5
La
Running lift kit, big tires or pulling a heavy trailer?
5867"]Running lift kit, big tires or pulling a heavy trailer?[/QUOTE]
14 inch rims with Kendra executioner tires .
