P1000 Ball Joints and Mileage
P1K5Dave
P1K5Dave
2,319
8,636
Petoskey, MI
What are you guys experiencing for ball joint wear? About how many miles have you gotten on them before they start to get a little sloppy?
Do the uppers typically wear faster than the lowers, or any difference that you know of?
I've got these automotive tie-rod end style ball joints on the Texas Tough Customs arms. I'm starting to doubt that they're up to the task, as I just had to replace a wobbly upper after 1900 miles. It's been making noise for a few hundred miles.
I did not think it could be a ball joint that early. I mean, am I looking at doing ball joints almost as frequently as an oil change? How does this stack up to OEM ball joints?
1005211829a
slowdryrider
slowdryrider
574
785
Canada
I've got 10,000 miles 16,500 klms on mine , still oems. I do add grease to mine twice a year by using a small grease gun needle. Just pry the rubber down a bit so I can insert the needle and add grease.
ToddACimer
ToddACimer
Pioneer 1005-2
3,804
16,187
Oshkosh, Wi
2000 miles on stock ball joints in super atv arms. Superatv a-arm bushings lasted about 1000. Garage products bushings now have 1000 and they are in pretty good shape but a little more play than when installed.
PJon
PJon
799
3,241
Arizona
i’ve got 3600 miles on mine and they‘re still tight. Then again, I’m usually following a bunch of Poo Poo’s on our rides.
Reactions: Lady01 and toddvdh
