P1000 3” satv bracket lift?
  • Thread starter Bigmanlittlebuggy
  • Start date
SuperATV
SuperATV
1,671
12,206
Madison, IN
www.superatv.com
I’m very confused on what your talking about I have a limited edition and I do have the satv arms on them
View attachment 358270 View attachment 358271 View attachment 358272
They physically bolt up just fine.... But I'm really surprised you haven't run through stock axles like crazy. They were binding up stock axles really bad.
Side Note:
I'm really glad you brought this up! We get to change the fitment on the website now, and show a fitment for the LE, but you MUST run the Rhino 2.0 axles. Basically...to prevent you from running through stock axles all the time.
So...good news all around!
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Side Note:
Yes and I really want to try the axles I just can’t afford them right now any chance you wanna send some my way as a sponsorship lol 😂 hopefully soon I have kinda maxed out my budget
Coeus
Coeus
Major General
75,195
686,585
Signal Mountain, TN
  2. Talon R4 LV
Side Note:
Well they didn’t fit until the Rhino 2s just came out for LE… every changing and always confusing
Coeus
Coeus
Major General
75,195
686,585
Signal Mountain, TN
  2. Talon R4 LV
I’ll take some new arched a-arms and Rhino axles for LE and do a review.. might let BBB even drive it to ouch it to the limits
E
elkrule
AZ
I installed the 3" lift on my 2017 P1000-5 LE. SATV knew nothing about LE upgraded suspension so was very confused with spacers that were not needed. We just cranked on the adjustable FOX springs. Ordered Rhino 2.0 axles but LE has extra gear so axles wouldn't work. Sold them. Have not had problem with stock axles yet but tires are wearing because can not adjust alignment or camber. I need new SATV a-arms to adjust for tire wear but then need new axles that fit. Has anyone actually installed new Rhino 2.0 HD axles for LE?
211,217
Big X on any lift spacers from anybody because of the non camber adjustment. Think your best route is to go with taller tires and forward arched A-arms, front and rear.
211,217
Essington
Essington
Wyoming
My 1000-5 LE started with the HighLifter bracket lift, and a fair amount of preload on the shocks. The 30" tires rubbed up front pretty bad when turning or at full squish. I would assume that the HighLifter and SATV brackets are very similar in that regard.
I removed the brackets and replaced the stock A-arms with the C-Fab forward A-arms, and now I have plenty of clearance with the 30's. Nearly 2000 miles and I haven't busted an axle yet. The stock LE axles do not seem to bind when turning with this setup.
So, On the LE you can do either bracket lift or A-Arm lift with the stock axles (I've never found aftermarket axles for the LE).
But the bracket lift will just screw up your geometry and not really get you much additional clearance for bigger tires, so I would avoid it.
Forward A-Arms (without an additional bracket lift) gain you some additional clearance while giving you a bit of lift as well. And at least the C-Fab arms allow you to bump up to 30's (or probably even 32's per the C-Fab web site).
I never tried to run the Forward A-Arms with the bracket lift as everything I read indicated that longer axles would be required, and they don't exist for the LE.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
FYI super atv just released rino 2.0 axles for le models I just installed mine today
Essington
Essington
Wyoming
Awesome, It is good to have options ... I have a spare stock driver's axle and upper CV, but have been waiting for months for a second upper stock upper CV (supply chain issues I guess). lucky I haven't needed them yet, and good to know that there's an alternative now.
