P500 2017 500 tic, did lash, manual plz
P
pioneergotictic
42
canada
Engine is out. Started to remove and bag and tag inspect. I’m stuck now on the front with removing the cluch basket waiting for my 35x1 puller, trying to utilize the pullers I have but not working out. Here’s some pics from behind front cover, closest machine shop is 2.5 hours away. Think I’ll take the crank/rod to them to measure wear. Searching bottom end rebuild kits bearings . Top end jug and slug. Aftermarket or stock what’s your 2 cents?
Image Image Image
193,130
View attachment 417158 View attachment 417159 View attachment 417160
Wow, that airbox is hit!
Reactions: Rdrcr and CID
P
pioneergotictic
42
canada
Bore $100 piston kit $180
Reactions: CID
906UP
906UP
14,914
141,768
da Yoop
I'm leaning towards oil starvation.....pump failure, low oil, deteriorated oil sorta thing. Regardless it'll need a crank, I don't think the rod is a serviceable part, add all bearings due to oil starvation :oops:
Might want to start looking at a reman engine, probably cheaper in the long run
P
pioneergotictic
42
canada
Yea for sure I was going g to check out Mots machining all the do is over bores and piston kits for powersports in my closest major city 2.5 hours away. Edmonton Alberta need an engine! Where’s the hook ups
I have wrote down the following so far to price out
Conrod cost pressing,Piston kit, over bore, front case O-rings, rear case O-rings, output shaft seals. Timing chain oil pump, head cylinder, tappet cover gaskets. New air filter, oil filter home made snorkel kit. The list is growing
  • Wow
Reactions: CID
906UP
906UP
14,914
141,768
da Yoop
Crank bearings for certain but if it were mine I'd be replacing all bearings
  • Wow
Reactions: Jason W and CID
906UP
906UP
14,914
141,768
da Yoop
On 2nd thought..... :oops:
Screenshot 20240207 201212 DuckDuckGo
  • Wow
P
pioneergotictic
42
canada
If on the fence about the bearings. Trying to consider what drivers I need pullers. Or washout the cases with the bearings in Varsol and then dry then wet with engine oil and turn it with my finger. I donno if this is the best for a customers machine I want a long lasting good job but I donno my local Honda shop says they don’t change em out. Clean oil and feel donno
  • Wow
Reactions: 906UP
P
pioneergotictic
42
canada
Im in canada so if you only knew how gnarly the difference and shipping I must look in Canada
Reactions: 906UP
P
pioneergotictic
42
canada
I’m sure it’s possible or this place sweet grass storage it the best way to go but.
I have to compare what my job vs what’s complete engine is shipped to my door, that 5k usd is 6700 plus shipping brokerage and then tax duty you name it it’ll be 8k Canadian
  • Wow
  • Sad
Reactions: 906UP and CID
906UP
906UP
14,914
141,768
da Yoop
Phuck dat.......for that price it's a good candidate to drop a T1K engine in it
Rayger143
Rayger143
3,281
28,639
Winfield, BC Canada
I’m in Canada too and I rebuilt a P1K. I ended up ordering all parts from Ron Ayers in US and after shipping and duty it was still cheaper. Might be worth a look. Create an account then you will get a lower price on a lot. Oem parts. Good luck.
P
pioneergotictic
42
canada
380 usd $90 shipping for the stuff I listed/\without account. Now $600 Canadian in the final of the billing, somewhere they add another $30 them coyotes.
290$Can con rod, $125 to instal, $180 piston kit. $100 bore @ machine shop. Add another $100 shipping or more
$80 abs 2” pipe, 90’s, couplers for snorkle kit. So this hopefully never happens again. Bring fresher air in then by the tire
Now I add 20% fork out my money,time on the phone, delivery picking up
Parts etc
Maby 12hr job @50/hr. Washed it, did valve lash. (I’ll prolly have more but trying to be fair I have no idea book time. My first honda 500.
$2350. Trying to estimate this out best I can for the guy
  • Wow
Reactions: CID and Rayger143
Rayger143
Rayger143
3,281
28,639
Winfield, BC Canada
Parts etc
Ron Ayers or Partzilla? Cheaper than your local dealer? Was for me.
P
pioneergotictic
42
canada
$380 usd without account for the stuff I listed /\ and main bearings.
thats Roy I didn’t check with llocal
Dealer but I should
Reactions: Rayger143
