P500 winch connection
kosh
kosh
42
104
Ste. Anne, Manitoba
I don't know what a power block is. However, after search this website I think I found a compromise. The positive connection is not a problem, but as it is so tight in the battery box, my negative cable is hard to tighten down. I will reattach the negative cable to the frame in a more accessible place and leave the positive attached to the battery. Removing one cable should make the battery box lid close better. Thanks for the replies.
193,457
Like a buss bar or fuse block, for power distribution. Instead of running all the accessories you add back to the battery, mount one of these under the hood.
BusbarFuse Block
Ransom
15
54
View attachment 342379View attachment 342380
I mounted one of these with 8gauge wire. Worked great. I mounted it where the owners manual goes, under the passenger seat cus there was too much voltage drop trying to run it under the hood.
the power cables to a winch are pretty thick. My question was, if anyone thinks I should stack another cable to the terminal or try to run that giant winch cable to that little bitty power box.
Reactions: Mudder
NTC/TAP Transition Member
11,837
90,112
Was able to fit a 6 ga. positive in the battery box, ran to a terminal post under the hood with an inline 300 amp switched circuit breaker mounted near the battery box on the seat frame behind the passenger seat. 6 ga ground to frame under hood. Example parts.
1FA641A1 2DD4 44A1 844A 4581C9692740AAE522D2 9CE3 4E8D 9646 86AA95968008
Reactions: Ransom
Ransom
15
54
View attachment 357369View attachment 357370
That’s great info to know!
I just wrapped this up today. Tan straight from the battery box with you. I left the inline fuse behind the seat, with make-shift cover to keep it out of the elements. Just wanted to keep it a littler higher just in case.
Was able to ground it where the seat hooks around. Saw a little bit of room there and it ended up working out nicely.
gonna secure the power block better another time. I don’t want to drill any holes, so I’m gonna be some weather proof Velcro-esque kind of stuff.
28D013A6 F0A8 44C7 A346 09DEB657A43F 84B3792C D83B 4D91 81AE 232D25042828 4E658BB2 EB1D 4AB8 995F B34D8593428D
Reactions: Mudder and CID
11,837
90,112
View attachment 357395 View attachment 357396 View attachment 357397
I have some exterior rated heavy duty adhesive backed velcro on hand, but still used zip ties. No issues after 5 years.
Reactions: Ransom
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
I ran my power to my winch from the battery. Is there somewhere closer to the winch on my 2015 Pioneer 500 that I can connect them?
Do you mean the relay? I put mine under the hood by the firewall.
Ransom
15
54
Good tip! I’ll definitely throw some on then 🍻
