P1000 Winch and clutch update
116,537
Talked to the dealership this morning they say that it was not a recall so since I didn’t didn’t ask about the update they didn’t do it even though it has been in for service under maintenance contract that I bought several times. Just like the heat on the seat
thank you for bringing this to my attention
I fought with the dealership and Honda about the heat on seat and they did nothing I showed them that I complained about the heat when it was in service they still didn’t do anything. So I sure they won’t do anything on the clutch update since I missed it. You would think when you spend money on a service contract that they would make sure all issues are taken care of
Have a great day
Yeah that clutch campaign has ended. Should have been a recall imo.
If hasnt, might be worth the $$ to have it done before an issue arises .
Here is how to look and see if it was done
IMG 5175
Also, the seat heat thing is a joke. Get u a quick shield instead. Much better
Reactions: TxDoc and RSM74
RSM74
RSM74
16
54
Arizona
Even though you might not anticipate adding any other excited l accessories, ones that require electrical power, as you get out and about.... You'll most likely add many things. And, it's much better to let that second battery be the source for that need.
And, your OEM battery will be safe to start your engine and reliably allow your transmission to function optimally.
Not, expensive, but go ahead and add the True battery isolator kit.
Good luck, you're on the right track. Keep on trucking.
On Edit ***
Man, while I was making a post, several others were already doing the same! Sorry for and duplicate info. You've come to the right place to get help spending
Thank you
Reactions: TxDoc
RSM74
RSM74
16
54
Arizona
Here is how to look and see if it was doneView attachment 408143
I will get this done this week when it goes in for service
Thank you
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Since you already got the winch, why don't you try it with one battery. I only have one battery and use mine on logs mostly and haven't had any problems. I would suggest a simple voltage gage. Also, when winching you should only winch about 10-15 seconds and then wait about 30 seconds before winching again. I know that may sound a little much but the battery in these thing are not very big. This will help you from draining your battery too fast. And, welcome.
You can get away with that short an off period "duty cycle" as the "on period" is a few seconds. BUT, and this is key, the duty cycle on most winches is on the order of 1 to 15 or 1 to 20 (one minute of hard pulling to 15 - 20 minutes of "off"/cooling time. Note that a typical 4,500 lb winch, like the Warn Axon that came on my P-1000-5, can draw over 200 amps at full load, and 30 amps while winding in almost slack rope. That's 360 watts of power consumed at essentially no load . . . so even no load it's got significant amounts of heat to deal with. Remember how hot a 100 watt lightbulb gets - - at full load, your winch is having to dissipate about 2,500 watts, and without the help of a cooling fan!
Scoop
Scoop
5,373
21,155
  3. Talon R LV
Pffffffffffff!
Just send it! It's only money! :p
Reactions: RSM74 and bumperm
