Will not start
Dordon
Dordon
42
130
Eastern Kentucky
I have a 2019 Pioneer 1000-5, I added a dual battery with Tru isolator had no problems for 2 years . But now when I try to start it I get no power, the batteries show 12.6 volts but the light on the isolator kicks on once in a awhile then i get a little crank not enough to start. I checked all the wires all are tight. When the isolator kicks in I hear a click then the light goes off. I am thinking the isolator has gone bad. Am looking for any ideas as to what may be the problem.
Reactions: ChadD and TxDoc
DRZRon1
DRZRon1
1,410
4,348
hi - please post pics of your ride - we like sxs porn
my advice is to check the main battery voltage and have it load tested - just may be dead\bad cell\etc. - the second auxiliary battery has nothing to do with the main battery not cranking the machine - just some technical facts that the main battery can just be bad and it is what it is - good luck and let us know what you find
Reactions: ChadD
5,737
26,291
I'd disconnect the primary battery from the isolator to test. Like the guys said, that's probably not the problem, but then you'll know.
Reactions: ChadD
