will 30 inch tires work with out rubbing
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
will 30 inch tires work with out rubbing on a talon 1000r
ITP Blackwater Evolution Radial Tire 30x10-15​
211,235
i was just looking at the reviews some people did not like them. have you had them before.
Yes and never had a flat. I'm running the Terra Hooks now, still made by ITP. Think there a better all around tire, just not as good in the mud as the Black Waters. ITP makes some great tires!
Cobweb
Cobweb
67
172
Hexi Hollow
I've been running them for about 1,500 miles now. 30 x 10 - 15 never rubbed. Overall a good tire, but they have their strengths and weaknesses.
Strengths: Mud!!!, soft dirt, good tread wear, smooth ride on pavement, light weight
Weaknesses: Mainly on loose rocks and gravel they search for traction. Uphill the rear wants to kick out a good bit. I also have Terrabites and they do much better on the loose gravel and rock.
If you're mostly slower speeds in the woods, they work really well.
Ride quality compared to the stock tires is a great improvement. (I run them at 9.5 psi with bead locks)
I have tore one side wall beyond repair with what I thought was not a bad hit. I also got another that I could plug. So, I can't say they have a anything better than average side walls.
Sheetmetalfab
Sheetmetalfab
2,413
15,381
Alaska
I’ve seen a lot of reports of sidewall damage…..
Above par with stock paper mache….. barely.
But if you go slow no problem.
211,235
HUGH? I ran mine hard at 9 PSI in the rocks on a P1 and never had any kind of issue?
Sheetmetalfab
Sheetmetalfab
2,413
15,381
Alaska
Maybe alaska is hard on chit but the local guy i trust and buy sled and sxs stuff from warned me away and showed me pictures.
(He knows me and my riding style, I was trying to buy the bwater evo’s)
Reactions: CID
211,235
I really don't know how to respond, Other than I'm no stranger to 4 inch sidewall ruptures and they weren't on ITP's. I hit something riding the edges at the TO, didn't bend tie rod, flatten a ITP or damage a rim, but damaged a A-arm mount? After the hit I just knew I blew a tire, nope! ITP's have been good to me. I live in NW Arkansas, nothing but rocks.
5,729
26,225
I’m running 30” Chicane RX tires (they have a rounded profile) on my R and testing the suspension limits out in the desert, no problems.
