P500 Which isolator for 2nd battery?
CSP500
9
Kentucky
True or Blue Sea add a battery for isolation of 2nd battery. In the planning stages right now and looking for plus/minus of each system.
Thanks
Rayger143
Rayger143
3,301
28,807
Winfield, BC Canada
True. I bought my kit at the Club Store. Works awesome.
CSP500
9
Kentucky
Will the True use any current in standby or when not in use monitoring both batteries?
Bigtee
Bigtee
556
1,213
Grayson, KY
I’ve had a True in my P1-5 for 5 years now, never had any issues. I also installed a True in my P520. I purchased from the Club Store also, I just bought the isolator because I had wiring left from the kit I bought before.
Reactions: Rayger143
DIRTBILY
DIRTBILY
279
3,033
Grantville Ga
Go with True, I bought the kit and did the install last week. It was easy and simple, if your gonna be in electrician mode then go ahead and a fused bus bar and stinger solenoid.
DIRTBILY
DIRTBILY
279
3,033
Grantville Ga
This is my setup
16257524155663001062425039847160
Dave75
Dave75
123
500
I have the Ture and no problems. Get the dual gauge to see what is going on.
1st photo is key on.
2nd photo is engine just started.
3rd photo is both batteries connected.
Good job DIRTBILY, looks better than mine.
4C686805 DAF9 4429 9935 27B18262D9B7 19DF946F 909F 43AF A8C1 06A985C01A4E DF885D8B 8416 44FF A963 21591C05A076 F284FE19 95E2 41CD A10C 0453256691B9
The Green Goat
The Green Goat
2,400
17,691
I think you would be fine with either. I went with the BS because I wanted the ability to turn the batteries off completely or to force them to lock together.
True would definitely have been an easier install.
DIRTBILY
DIRTBILY
279
3,033
Grantville Ga
Thanks
View attachment 282600 View attachment 282601 View attachment 282602 View attachment 282603,
Thanks took a couple of evening to figure it all out on where to fit everything. The wiring was straight forward
