P1000m5 Which Battery for dual battery set up 2022
someguy1313
someguy1313
241
522
SouthEast
still following... about to replace both of mine :/
(if anyone has any tips/tricks on desulfating i'm listening)
Reactions: ChadD
bumperm
bumperm
1,927
6,825
Gardnerville, NV
I used a Might-Max with Tru isolator, like many others here. Recently replaced the battery on our ride-on mower with a lithium ferrous phosphate battery (LiFePO4). Designed to last a whole heckofalot longer than lead acids, much lighter weight and can be fully discharged without cumulative damage (so long as it's charged back up soon-ish (unlike lead acids that loose capacity and life if discharged below 50% or so.
This one: Amazon.com
Note this was not used in my P-1000.
Vikes79
Vikes79
SKOL!
11,995
115,374
South Dakota
  2. Talon X4 LV
If I were to do my P1k5 again…I’d skip the isolator bs and go straight to a disconnect and a car battery under the drivers seat. If you got big continuous draws, you’ll hate the isolator.
Seriously…cheaper, and far cleaner.
My winch, heater, lights when im plowing snow absolutely make the isolator wigg out in short order.. I got the same problem when im spraying pastures at low ground speed and the cooling fan, under seat fan and my spraying pump are all running wide out.
last winter I just bypassed the isolator and paired up the two batteries. No problems since. I’d put a car battery under the seat, but I already have a heater there.
Just a contrary opinion from my experience.
Reactions: trigger
