what did you do with your pioneer today
21,720
92,898
Finally hung my plow, trying to get ready for the season. Also installed my plates. Not a fan of rear location, but I needed a quick install so I could run some errands. I will probably put it at top center between speakers and wire in some LED bolts.
EAA11D96 9E7D 446B 9885 05C41308220B
AD0EB31B 7EBF 44C1 B7DD 97AE628B53CB
G
GolfCart
148
424
NH
Added the Honda under dash storage tray to my 2020 P1K-5. Nice addition and easy to install other than a bit difficult to get the push pins to work with the added thickness.
KellyK
KellyK
6
47
Oregon
I spent 3 full days riding around the Oregon Dunes National Recreation Area. It was a blast. I was surprised how well the P700 did in the sand, with stock tires and suspension! I couldn't keep up with the big boys, but still had a good time. And I only got stuck once. However, even the more capable vehicles in our group got stuck at least once. I could not charge straight up the big, steep dunes, but I could get almost anywhere if I was careful in choosing my path. And I definitely found the limits of the P700's suspension.... hope it didn't knock any dental work loose.
20230716 125606
Scoop
Scoop
5,380
21,174
  3. Talon R LV
Had to try something to slow down or stop the leaking Terrabite Aramids, so I added ~25 oz of Berryman Seal-R to each tire. Hung them horizontally (top & bottom) to try to distribute some to both bead areas. Not sure if it will help, but we shall see when I check tire pressures in a few days.
Mudwisel
Mudwisel
10,118
83,673
Tampa Bay Florida
Had to try something to slow down or stop the leaking Terabite Aramids, so I added ~25 oz of Berryman Seal-R to each tire. Hung them horizontally (top & bottom) to try to distribute some to both bead areas. Not sure if it will help, but we shall see when I check tire pressures in a few days.
Never a problem with the megabites at all. Have the same air from day 1
Scoop
Scoop
5,380
21,174
  3. Talon R LV
Never a problem with the megabites at. Have the same air from day 1
Beadlocks?
The Aramids are 10-ply, too. Super thick beads.
(Sorry, just noticed this was the 700 forum)
Reactions: BrianN and Mudwisel
