What are these?
NewHere2
NewHere2
Village Idiot In Training
53,857
386,258
High Plains of SD
Those are connector holder tabs for the wiring under the dash. For the switches in the dash
Troof dat ! But it’s important to remove dem in the proper sequence !
It’s the same sequence as the firing order of a 1946 Farmal 4 cylinder tractor :
1 - 3 - 4 - 2 Hope dat helps.
NewHere2
NewHere2
53,857
386,258
High Plains of SD
IMG 0356
The tabs hold the wires for the switches in the dash.
If you squeeze the tabs together with a pliers, you can push them inside.
You can cut an access hole as shown in the picture. Best to leave those 4 mounts, but you can do what works best for you.
Best to leave a rim around the outer area for mounting a cover plate. Again what works best for you.
All the wires coming out the cutout are extra ones I installed. Nothing in the way back there, just use common sense and don’t cut to deep.
Sure makes it easier for mounting switches in the lower row.
Good Luck.
BigSG
California
Good Luck.
Thank you! Some great advice. I am planning on leaving them alone. I ordered a flush dash mount and will hopefully stay away from them all together.
Crossroads 3D Dash Mount Compatible with Auxbeam 8-Gang Switch Panel and Honda Pioneer 1000 (2022+) Mount The 8-Gang Panel to Your P1000 Dash
https://www.amazon.com/dp/B0BVXJ299L?tag=sxsweb24-20
Reactions: Remington and CID
