nitzo
As I had mentioned in a previous post. When I had that grounding issue and was stuck in 1st gear it caused my rig to overheat and I boiled a bunch of water out and I refilled it with just plain water. Well, I'm going to redo all the fluid in the system. First, what is the best way to drain everything and then refill without getting any air in it. Second, what kind of ratio should I use for the antifreeze to water and should I use some water wetter? Thanks all.
