Valve adjustment at 2,000 Miles?
DRZRon1
DRZRon1
1,437
4,395
I ain’t hondatech here but….. seems to me
unless it’s having a problem starting or valves really ticking or just want it done….
1. First step is to authorize valve clearance inspection.
2. Based on that - determine next step - would you really make a swing at it if it was out .001” and who knows - may have left the factory out a little.
My hunch is is 80% of the machines out there haven’t and won’t get the valves adjusted - ever - and will run run run run……
Jerryg
Jerryg
12,251
96,697
NEPA
If you are checking, you are adjusting the time difference is minimal.
Scoop
Scoop
5,408
21,274
  3. Talon R LV
A buddy of mine has a 2021 R, he has it in the shop for service, yea he doesn't work on it, and they are telling him it needs a valve adjustment and it cost $455.
BS or not?
Did your buddy ask them HOW they KNEW it NEEDED a valve adjustment?
Reactions: TOGR and WagginTail
BS or not?
I usually have to adjust exhaust at the first service, but those are screw adjusters.
We charge an hour for inspection, and if needed adjustment on the exhaust only.
I've never seen intakes that warranted removing the camshaft. Loose on the shim style valves is OK, they only tighten up.
Buy even then, I would probably wager, you could pull the cam and shim all 4 in under 3 hours if your familiar with the procedure. The worse part is the exhaust rocker shaft removal, it requires the whole back panel behind the seats to come out.
bigred1000-6
bigred1000-6
Buckeye,AZ
  1. 1000 6 Crew
How much of an adjustment..? Thx
Reactions: ChadD
TOGR
TOGR
82
411
NW Montana
  1. Talon R LV
Thank you, HondaTech! And a shout out to your dealership for being honest and putting the customer first! If all dealerships were like yours, a lot more folks would trust them to perform their service. Your voice here is so appreciated!
211,962
I'm looking for a ball park # for what it costs to tear down a 16 P1 and replace a broken ring. To see if I need to trade? I'd tell them it uses oil. 4,500 miles and 1 quart missing in 450 miles, well taken care of, no dust past the air filters ever.
Reactions: ChadD
Has the broken ring been verified? I never seen a Honda ring break, most likely there's another problem or the rings/cylinder is worn enough to burn it.
You can remove the piston/rod in frame, but if the cylinder needs replaced, the cases have to be replaced.
Just to pull a piston, you'd probably be looking atleast 2-3 hours, which at our ship is $200-$300.
Reactions: Smitty335 and ChadD
ChadD
ChadD
29,651
274,645
Brown City
Does that include the #NTC 0% discount 🤔
211,962
Thank You! I figured $ 1,000.00 to $ 2,000.00 to repair it right, think it's time to trade with oil disclosure. I'm sick of this Honda.
Reactions: ChadD and Backwoods
