P1000 Trail armor full skids with 30" Tires and SATV A arms Update! they fit without trimming.
codyroach
codyroach
19
81
Ruston, Louisiana
Hey guys, I am about to install SATV ATLAS 1.5" forward A arms and 30" xtr370 tires, I already have the trail armor full skid, I am wondering how much trimming if any I will need to do to the skid.
Thanks,
20191126 120735
Russ989
Russ989
22,645
147,291
Thanks,
If you put in steering stops you should be good to go, if not you’ll only hear it at full lock. That’s assuming you’re installing wheel spacers.
codyroach
codyroach
19
81
Ruston, Louisiana
Running 30" XTR370, on Black Rhino 14x7 5.5+1.5 offset SATV atlas 1.5" forward A arms. I'm not completely done with the install, still have other side to finish. Looks like everything clears. I will have to order a spacer for the rear, probably 1". Also I'm not running the steering stop.
20230421 121213 20230421 121216
Scoop
Scoop
5,391
21,202
  3. Talon R LV
My Trail Armor skids and 30x10x15 Tusk Terrabite Aramids on 15x7 Tusk Uinta beadlocks have no issues coexisting. The tires actually measure right at 29" tall.
ToddACimer
ToddACimer
Pioneer 1005-2
3,808
16,208
Oshkosh, Wi
I was fine on skid plates and inner fenders but I trimmed at least 3/8" off under the head lights. You may rub wheels on the back side of the a-arms. Careful with the brake line routing if you skip the steering rack stops as they may get pinched at full steering lock.
TripleB
TripleB
20,538
179,637
Caryville, Tennessee
I was fine on skid plates and inner fenders but I trimmed at least 3/8" off under the head lights. You may rub wheels on the back side of the a-arms. Careful with the brake line routing if you skid the steering rack stops as they may get pinched at full steering lock.
I smashed both my stainless brake lines on the same ride. Put stock lines back on and rerouted them on the other side of the a-arm. Good to go since.
TripleB
TripleB
20,538
179,637
View attachment 384119 View attachment 384120
I have the same set up but with 30 inch blackwaters and they rubbed the inner fender and the skid plate on turns and full compression of the suspension. Had to put a screw in the inner fender and trim that part that turns up on the skid plates. No rubbing after that.
WagginTail
WagginTail
1,645
6,044
SC
Here's how I rerouted my brake lines. Drilled and tapped a new mounting hole in the arm. I have had zero issues with them like this
20220618 142745
20220618 142515
codyroach
codyroach
19
81
Ruston, Louisiana
Yeah, I was wrong I had to install the steering stops. My tie rods were contacting the upper arms and smashing the brake lines. I also went with the RB3 wide track spacers 1" in front 1.5" in back. I may re-route the brake lines and try the newer style 22 up tie rods, then i could probably remove the steering stops.
Edited to add photos
20230502 194708 20230502 194716
Scoop
Scoop
5,391
21,202
  3. Talon R LV
My update: My 30x10x15 Terrabite Aramid tires DO rub the TA skids when the shocks are compressed. Learned that this weekend in LaFollette. Gotta trim them.
