Talon Sway Bar Shock
SuperATV
SuperATV
1,648
11,958
Madison, IN
www.superatv.com
Talon Sway Bar Shock​
Link: https://www.superatv.com/honda-talon-1000-sway-bar-shock
Details:
  • Shock-absorbing coils give you a smoother ride
  • Made of hardened and black nitride-coated 4140 steel
  • M12 x 1.25 threads
  • Easy bolt-on installation
Kit Includes:
  • (1) Sway bar link
  • (4) Spacer bushings
  • All hardware
Fitment:
  • Honda Talon 1000R : 2019+
  • Honda Talon 1000R-4 : 2023+
  • Honda Talon 1000X : 2019+
  • Honda Talon 1000X-4 : 2020+
NOTE: Fits OEM and aftermarket trailing arms
Get More Control with a Honda Talon Sway Bar Shock
You like to cruise through winding trails and over whoops. But when you put the pedal down, you can lose control fast. Keep your UTV in contact with the ground and get better control with SuperATV’s Honda Talon Sway Bar Shock. It replaces a sway bar link with a shock-absorbing link that allows your suspension to articulate better. It lets you corner hard without rolling your Talon.
Improves Your Talon’s Suspension
Standard sway bar links can stiffen your suspension, and when you turn hard, you can end up on two wheels. Our Honda Talon sway bar shock lets your suspension move independently without inducing uncomfortable body roll. That way, your tires stay in contact with the ground, and your Talon stays centered.
Sold Individually
One Honda Talon sway bar shock is usually good enough for most riders and makes a huge improvement to ride quality. The most aggressive riders will want to opt for two sway bar shocks to stay in control at max speed through whoops and races.
Built to Last
These sway bar shocks are meant to be driven hard—that’s why ours are made from zinc-coated 4140 steel. They’re strong enough to take constant abuse, and the zinc coating prevents rust and corrosion.
Installs Easily
Installing this sway bar link on your Honda Talon is super easy. It’s a simple, bolt-on process with our included bushings and stock hardware.
NOTE: Sway bar shocks are sold individually.
DRZRon1
DRZRon1
1,388
4,285
You all are awfully proud of these - like $360 for 2 sway bar shock links?
SATV is a leader in the aftermarket make it bigger,better, badder stuff so appreciate all you do.
Just not sure SATV missed the market compared to the other options of <$100 for the pseudo shock solutions already out there.
But then again I’m always amazed at what folks can afford.
SuperATV
SuperATV
1,648
11,958
Madison, IN
www.superatv.com
Development and production of shocks is expensive! Ours aren't too bad. The FOX ones from ST are over $1k each!
These are really cool. The RZR and X3 guys LOVE these things.
Reactions: ChadD
DRZRon1
DRZRon1
1,388
4,285
everything from ST is expensive - lol
their limit strap prices are for those with more money than brains - and I’m jealous of that
  • Haha
Reactions: SuperATV and ChadD
Similar threads
