Talon billet remote filter adapter -10 ORB
GBell
GBell
103
144
If you are like me and think that little filter is being asked to do a lot this might help. A way to add a remote filter and or a oil cooler if you choose.
And for looks I'm working on a billet DCT filter cover also. I'm on FB under Bell Engine's or text 417-619-8514 I will fix you up. I can also fix you up with my custom ARP Talon head studs. They provide full thread contact in the block which means less cylinder distortion. I also had custom washers made for even load across the entire spot face of.
You can see the difference in the picture old versus the new custom stud also size difference between the washers & nut.
IMG 20230830 212247 944 Screenshot 20230815 182428 Instagram 20230901 170919 Screenshot 20230827 204443 Gallery
SLOWPOKE693
SLOWPOKE693
2,019
7,826
Somewhere in Texas
I have the Bell remote oil filter mount and the head stud kit on my race engine. Both are top notch and well thought out products. Highly recommend both!!
Mark in Northern Iowa
501
2,217
Floyd County, Iowa
kramnella.wixsite.com
View attachment 401696 View attachment 401697 View attachment 401698 View attachment 401700
Can you post a picture of the inside of the oil filter bypass cover?
Trying to wrap my head around how it connects inside the oil filter housing for the oil flow.
I looked online, with no luck.
Thanks.
Have a good day
SLOWPOKE693
SLOWPOKE693
2,019
7,826
Somewhere in Texas
Thanks.
Have a good day
It has a tube machined into it with O-rings that seal around the stub that the oil filter slips on inside the factory housing. Oil goes in to the Bell adaptor through the tube, out the "out" port to a remote filter housing and then back in the "in" side on the adapter.
Reactions: TxDoc
211,812
I would thinkni would want to change the oil before that filter ever gets full.
But that's me
You could keep the same interval your used to though. I like to change oil frequently so I can take a look at the old oil, I even drain the DTC into a different drain pan than the engine oil.
GBell
GBell
103
144
You do know that the engine oil is shared with the DCT oil?
Reactions: Smitty335 and TxDoc
211,812
Yep, I just want to see what settles in the pan in both. I've always assumed the DCT filter filtered the oil from the clutches before being pumped back in to the crank case, so I see your point, does the filtered DCT oil go through the main filter also before it goes back to the crank case. Guess I need to get my book out.
Reactions: TxDoc
