Will removing the sway bar effect me towing my 14’ trailer through my yard? I have 26x9x12 and 26x11x12 bear claw htr on stock rims with no wheel spacers
Not a bit.
I didn't see any of those gates... rode the area for a week.Don't go on any 50" trails with those spacers, if you get through one end, you not get out the other end. My sway is disconnected, but then again I'm not into high speed driving on the straight line or in corners. I spend about two weeks in Colorado driving all over those trails west of Delta and Montrose. My best investment has been tires, Torque Locker, and Walker Evans shocks for the front.
The 50" trail heads are marked on the USForest Service maps. Trust me, they are there. You just didn't hit the right trail. But, as you already know there is plenty of riding opportunities without ever going on a 50" or less ATV trail. It's just nice when you encounter one, you don't have to turn around and go back.I didn't see any of those gates... rode the area for a week.
I've had mine off for like 4 month And i promise you you will not roll it over on a power slide ...So much better with it off.I'm going to try removing it before our next ride. I'm not too concerned about a rollover while I'm driving it. However my wife's offroad and trail riding background comes from riding and racing banshees and the like. The phrase, "drive it like you stole it" comes to mind. May be a bit tough to get her to take it easy a bit while we learn the new feel of the swaybar disconnected.
Going to give it a try.I've had mine off for like 4 month And i promise you you will not roll it over on a power slide ...So much better with it off.
Those pictures will save a lot of trial and error, thanks!I took mine out in one piece from the passenger side with wheel off,a little tricky but you'll figure how to slide it out..I also marked the sway bar just in case i have to install it back..
View attachment 147814 View attachment 147815
Plenty have just disconnected and zip tied it up out of the way.Would it be ok to just leave the SB in but disconnected?
Took mine out the other night. Completely removing it took about 5 minutes from start to finish. Incredibly simple. Lift the rear with a jack, take off the passenger side wheel, 12mm socket to remove the swaybar links from the arms, 15mm to unbolt the swaybar from the frame, and it slides right out like in the pictures. Put the wheel back on and done.Would it be ok to just leave the SB in but disconnected?
I found that disconnecting one side would allow the loose side to contact the a arm under max twist.2016 P500. I've disconnected One side only and zip tied it out of the way. That's all it takes unless you like to do extra wrenching...
I did a little test tonight. I set up a ramp and then backed the P5 up the ramp until the front wheel left the ground. He's how far I made it with the sway bar connected:
20190828_191254
- Tstover
With one side disconnected:
20190828_192652
- Tstover
As you can see, the sway bar contacts the A-arm, which makes it still act like a sway bar.
20190828_192703
- Tstover
With both sides disconnected:
20190828_193519
- Tstover
It did make a difference with both sides disconnected, and as you can see, the sway bar is not contacting anything with both sides disconnected.
20190828_193532
- Tstover
I plow with mine and no issues!!Thinking about taking mine off but don’t know if it will effect when I’m plowing snow any ideas thanks
