P500 Superwinch Terra Solenoid Question
F
Foss
14
66
Vermont
So.... long, comedy-of-errors-story short, I dropped my solenoid from my superwinch terra 45 on my concrete garage floor while fabbing up my install. It looks fine but I shook it and something sounds a little loose inside. I didn’t shake it before, lol, so no idea if this is normal or not. Should I just order another one? It’ll be a bit of a pain to swap out once it’s in so I’m trying to figure out if I should be concerned or not. Thoughts??
Bigtee
Bigtee
556
1,213
Grayson, KY
I just installed mine but didn’t remember any rattle in it. Can you hook everything up and test before you install it?
Reactions: Foss and bpike207
F
Foss
14
66
Vermont
Yes, that would be easier than finding out after the final install of everything. Thanks!
68,239
I agree... It shouldn't rattle inside.
IDK... If it sounds like rocks.. Ya. I wouldn't install it... lol.
Reactions: Foss
F
Foss
14
66
Vermont
Thanks guys. It sounds like one piece moving, and not a lot but it’s obvious. I’d thought about testing like bigtee suggested or if I can test with a multimeter somehow. Bottom line, even if it worked out, I don’t know that I’d have confidence in it now anyway. Do it right, do it once.
I think it’s time to order a new solenoid.
Reactions: Bigtee
bowhunterbill
bowhunterbill
440
1,351
Bozeman, MT
Call the manufacturer and ask .
It shouldn’t break falling to the ground given the shock environment when mounted in a UTV.
Who knows- maybe they’ll send ya a new one for free if you’re nice on the call.
Reactions: Foss and Bigtee
F
Foss
14
66
Vermont
Hi Bill-
I had the same thought so called this morning. The person I spoke to said they’d recommend ordering one even as a spare, and they wouldn’t have any to even buy until September. He said if I can find one at a different retailer I should order there. I did not push too hard since it was my fault but I was hoping for a little more help. Summit racing had them in stock so I’ve got another on its way.
I also agree it should be able to withstand that drop, and it may be fine. But without knowing if it “rattles” normally, I don’t trust installing it. Worst case, I have a spare on the shelf lol.
appreciate the feedback guys, thank you
Reactions: Bigtee
