P500 Steering stops
Bomersteve35
98
307
Portland or
  2. Other Brand
No but why would you be worried? Are you worried about getting stuff in a bind from a rock or trail? I'm not putting down your question I really want to know what your thoughts are and why or what would it do or fix or keep from breaking stuff thanks
Peter_72
Peter_72
792
6,540
Louisiana
I’m running bigger, heavier tires and just before the steering is at full lock it feels like it just flops and will get stuck. I have to back up a little to get it unstuck. I think the stops might prevent that.
196,860
Those tires are just too big without arched A arms or something. You're rubbing already and that's not at full suspension compression. Given the right situation you might not be able to move at all.
Peter_72
Peter_72
792
6,540
Louisiana
I made new mounting tabs to move the arms forward but I was hoping to try this before I started welding on the frame. I guess I’ll have to just move them.
NTC/TAP Transition Member
11,888
90,655
Curious as to what size tires you have. 27s here and no rub. Many have cut tip of the frame for 28s.
The Green Goat
The Green Goat
2,443
17,990
Bringing this back. Thinking about adding some steering stops to mine if I can't figure out why mine is binding when I tear it all apart this winter. Got in a crap situation this past weekend; Going down a steep and rocky hill, trying to avoid falling into a deep rut, kept sliding sideways and eventually into a rock with my steering turned Driver. Steering was locked up tight to Driver, couldn't back up due to steepness of hill. Couldn't turn Passenger to get off the rock. Had to be winched backwards a bit to take the bind off the steering before it would finally release. Super annoying. Not to mention my fear of breaking my steering in some way out in No Man's Land.
@Hondasxs and I legitimately thought it was broken due to how far the driver-side tire was turned (probably ~80*).
Reactions: futzin
futzin
futzin
4,828
35,397
Kentucky
This sounds a bit familiar . . .
Reactions: The Green Goat
The Green Goat
The Green Goat
2,443
17,990
Reactions: futzin
futzin
futzin
4,828
35,397
Kentucky
So, what components do steering stops protect?
The Green Goat
The Green Goat
2,443
17,990
My guess is to take the load off the rack when pinned hard to one side. Essentially, the stop takes the brunt of the impact instead of the teeth inside the rack.
Reactions: ODAMO
