P700 Spare tire / wheel decision
KevP700-4
KevP700-4
268
638
Northern MI
Have a ‘21 700-4D. Got new tires to put on the stock aluminum wheels (27x9-12 and 27x11-12). My old tires are the stock 25x8-12 and 25x10-12. I would like to buy a new steel 12” wheel so as to mount an old front tire (25x8-12) to use as a spare. What are your thoughts? Is this the way to go considering different stock front & rear wheel offsets? Any better way to do this? I’m not interested in buying a full set of wheels and a set of all the same size tires. My spare as planned above would be for only emergency use to get back to home or a repair facility. Your thoughts…THANKS
BTW: I bought Tusk Terrabites tires to replace the OEM treads. Got 850mi out of the OEM tires, mixed blacktop/trail use.
john790
397
1,154
Clinton ohio 44216
I am kinda doing what you want to do also.Just take one of the fronts and put it on the and ck for clearance problems.If none buy a front steel wheel.But on the back as a spare with a 25 its going to fight alot.You would be better off with a used 27 tire for your spare.If not take your best 25 and keep the air up about 20psi.Because of the diff being locked in the rear.
KevP700-4
KevP700-4
268
638
Northern MI
Yeah, was going to check out the front to rear with the 25”. Good idea though pumping that 25” spare up to 20 psi or sidewall max, that certainly would help. Thanks John!
KevP700-4
KevP700-4
268
638
Northern MI
For reference the Pioneer 700-4D aluminum wheels are: Front 12x6. Rear 12x7.5
Squirrel Man Sam
Squirrel Man Sam
9
37
Quartzsite, AZ
For temporary use, using a shorter tire may not cause damage, but for me, not knowing how far out I would be when I happened to get a flat, this was a no go. Usually seems like stuff breaks when you're the farthest away from home and help. I recently upgraded from the originals to 27" Tusk Terrabites as well. Around here, there's used sxs wheels all over on Facebook Marketplace, so I just bought a used one from someone who upgraded their base Pioneer's steel wheels. I bought a front wheel, as that'll work on all 4 corners. When I got my new Terrabites, I bought a used 27x9 tire with decent tread left, from the place that I had mount the tires, and had them mount it on that spare.
KevP700-4
KevP700-4
268
638
Northern MI
That sounds like a good way to go. I need to check with the dealers around here for a takeoff wheel, maybe even a tire. I’ve seen lots of folks buy a unit wit steel wheels and swap for aluminum before delivery.
