P1000 Snow Plow for Sealed Asphalt Driveway
ehart814
ehart814
1,701
3,888
NWPA
This spring, we moved to a new home. I'm not used to the luxury of having a paved driveway, but I guess we are moving on up!
I have always had gravel driveways and when I plowed snow I just have the skids maybe 3/4" down from the blade and that's how it's currently set up. Couple years ago I went the cheap route and bought the 72" Tusk plow setup from Rocky Mountain for my 1000 and it has done fine. I had a better plow when I had my 500, but I don't really enjoy plowing all that much and this time just decided to cheap out.
Anyhow, my driveway is really nice and I have no experience plowing on asphalt. Are the metal skids going to damage it? Obviously, I know about the plastic cutting edges and read a bunch of threads on here but didn't really see anything about using the steel edge and skids on asphalt. I don't care to scrape every millimeter of snow off. I plan to use my little broadcast spreader on the back of the Recon to spread sand after I plow. I think that will work great for traction and to help melt the last bit of snow.
Does anyone here have experience using steel edge on sealed asphalt ? Any tips? I don't want to buy a plastic edge or really do much work on the blade. Hoping I can get by with the current setup without causing damage
Reactions: ChadD
Vikes79
Vikes79
SKOL!
11,952
115,148
South Dakota
  2. Talon X4 LV
You’ll definitely want to have the blade up a bit, especially if you hit some seams or cracks.
personally I’d leave the skids so you gave a 1/2 to 3/4 clearance and let the sun do the rest. If you’re plowing when there’s snow then there should be minimal wear on a set of steel skids or shoes.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
I made ski type skids, as @Dirtstiffs-1000 suggests, out of 3/4" thick UHMW-PE. The skids are mounted to a steel plate with countersunk bolts, so some of the UHMW thickness is "wasted", but still they last a good long while on my tractor mounted
blower. I made the cutting edge of the same material, cut on my table saw. I found the Peachtree Woodworking has about he best prices I could find: Peachtree
Also note the 1/8" UHMW lining the blower chute (since this was taken, I've also lined the impeller blades with and main housing with 1/8" thick UHMW . . . does an amazing job of preventing clogs when dealing with wet sticky snow. Here's a video clearing a neighbors driveway - throw is a about 75 feet.
O9wr6zW
Scoop
Scoop
5,391
21,202
  3. Talon R LV
You want the second solution posted here. Been using the same piece of conveyor belt for 8-9 seasons now.
Get it here: 72inch
I suggest you get the one with NO holes and just drill them for your blade.
Not only will it not damage your driveway, but you can literally push snow across your lawn without damaging it.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Get it here: 72inch
With the UHMW-PE, you won't want to cross your lawn, that's for sure. But I think it'll do a better job scraping up ice and such than would the rubber conveyor belt material. If going with the rubber, check pricing at Home Depot . . . looks to cost less.
Scoop
Scoop
5,391
21,202
  3. Talon R LV
The rubbery conveyor belt removes damn near everything from a sealed asphalt driveway (thin sheet of pack) and is lawn safe.
The stuff at Home Depot isn't even half as thick as this stuff. It would fold like a cheap lawn chair.
ODAMO
ODAMO
1,385
3,645
UTVs are too light to expect them to scrape all ice away, it’s best to not even try. The rubber is very forgiving.
Scoop
Scoop
5,391
21,202
  3. Talon R LV
I just ordered one. Been putting a beating on my concrete, mainly at the control joints. All the 5" are sold out so 4"x 66" it is. $85
You won't even notice the joints anymore. No more plow slamming forward/down and bringing the bike to a halt, and no more having to replace stretched out plow springs every few years. The rubber is thick and heavy enough to move most all the snow, yet forgiving enough to glide over the top of the changes in surface heights. Your nerves will thank you. :)
And no more buying replacement steel wear bars every year or two.
When I ordered mine, I intended to order the 4", as that was going to be sufficient. However, he was out of the 4" and he said he would ship me the 5" at no additional cost because he already had some 5" cut, but no 4". So you should be perfectly fine with the 4".
This stuff seems to last forever, but ... when you mount it: If you are able to drill the holes exactly centered between the top and bottom (of the two long edges), you'll be able to flip it over and use the other edge if/when the edge you initially have on the ground wears down or gets damaged.
