P500 Skid Plate Spacers
futzin
futzin
4,761
34,945
Kentucky
I'd like to add spacers to my SSS skid plate to help clean/clear mud from underneath when pressure washing.
I don't think they'd need to be very tall, 1/8 or 1/4" maybe.
What material would work, inexpensive?
Or maybe stack some galvanized or stainless washers?
The Green Goat
The Green Goat
2,399
17,688
I'd maybe try to find some made of UHMW plastic, like the skids, and then see if I could solder/melt them to the skid plate so the install would be easier. Or I suppose you could just glue them.
21,734
93,038
I found some options on McMaster. Although I would have concerns about spacing the entire skid that far away from the frame. I would think the skid directly on the frame adds an insane amount of support. I would be tempted to drill a few extra holes where you want everything to drain.
But, here are some plastic options.
I am not sure how large an OD you need to support the skid/washer assembly.
1718625838582
1718625885576
Reactions: Fatsquatch and CID
Red500
Red500
6,557
70,501
Greeneville, Tn.
Maybe use a hole saw and cut them out of the stock skid ?
futzin
futzin
4,761
34,945
Kentucky
Red beat me to it!
Not crazy about this idea. Gonna let in a LOT more debris: rocks, sticks, grasses, etc.
Plus probably act like a cheese grater on dirt and mud when dragging, belly sliding, etc. Impacting/compacting until wash time can happen . . .
Appreciate the responses . . .
Red500
Red500
6,557
70,501
Greeneville, Tn.
Plus probably act like a cheese grater on dirt and mud when dragging, belly sliding, etc. Impacting until wash time can happen . . .
I'm saying cut washers out of you old stock skid plate.
KyGal83
KyGal83
9,553
93,104
Kentucky
Folllowing… I need to do the same.
I would rather not cut drain holes in skid as well.
My original skid plate went in the dumpster as soon as the upgraded one went on.
Red500
Red500
6,557
70,501
Greeneville, Tn.
I drilled a couple of drain holes in my skid plates. It doesn't seem to hurt anything but I'm not sure it helped any either.
